Very Little Boost...8.1L Rear Mount
OK, got the turbo on, and I am seeing very little to no boost. And lag is horrible. I have two wastegates before the 76mm Precision Turbo. Springs are .2bar, so like 3-4lbs springs. With both wastegates hooked up, I am seing like 1 pound of boost, and NO WASTGATES, I see like a max of 6-7lbs. Shouldn't this thing be able to make like 20 lbs. And I see NOTHING in 1st gear, no matter what, but second i can see bout 3 lbs, and 3rd and up like 6-7. That is with NO wastegates at all. Is it maybe a major Boost leak that i am just not seeing??
Tierods truck spiked to 17# before with the precision 76. What size wastegates you runnin? Also have you tried to compress air into the charge side? Might be having a leak somewhere in the charge pipe.
