valve float??
Old Mar 26, 2008 | 08:26 PM
terravast4's Avatar
Default valve float??
How do you know if you are getting valve float? Sometimes at a full throttle downshift I can hear the radix in boost the rpm's are high as **** but it just feels like it is taking forever at part throttle downshifts the engine is far more responsive and pulls like crazy. I am wondering if i am getting valve float and I losing boost through the exhaust side? What do you guy's think? anyone experience this? Do I just need some better valve springs?
Old Mar 26, 2008 | 08:32 PM
MikeGyver's Avatar
They sound like they're gargling when the valves float.
Old Mar 26, 2008 | 09:06 PM
Mangled03gmc's Avatar
Baltimore Whore
You will lose power when your floating the valves. What is your redline set at??? If it isn't over 6200 I doubt you are floating the valves unless you have a ton of miles on yours..
John
Old Mar 26, 2008 | 09:20 PM
jkwalkercchs's Avatar
ls7 lifters will help there cheap
Old Mar 26, 2008 | 09:59 PM
nightrunner's Avatar
Mr. Obvious
valve springs will help him more than new lifters will when it comes to valve float
Old Mar 26, 2008 | 11:15 PM
terravast4's Avatar
I am mostly feeling it around 6000 rpm. Is it maybe p0wer falls off just before that and 4000 rpm's has gobs of power? whan I had the stock pulley i did not have this problem but when I went to the 2.8 I noticed it. I am hearing a fluttering sound like if there were old dried up leafs in a cardboard box bouncing around. this is the best way i can describe it. I thought i may be getting detonation but I did a plug reading before going to the tr6 and they looked just fine. Do you think valve springs would be a good investment and maybe some 1.8 rockers??
Old Mar 26, 2008 | 11:41 PM
charcold-bowtie's Avatar
I wouldnt do the rockers, but some yellow ls6 springs would never hurt anything IMO
Old Mar 26, 2008 | 11:55 PM
Stoichiometric's Avatar
Is your belt slipping? The ls7 lifters are the same as stock, the caddilac lifters are the improved version, FWIW. Springs would be a good investment, and get you ready for the cam of your choice.
Old Mar 27, 2008 | 12:05 AM
terravast4's Avatar
not sure about slippage but I did throw a belt a week ago and it was shredded. about a month after switching to the 2.8 pulley. I am getting the metco 100mm idlers and the new tensioner pulley from magnacharger. hope that helps.
Old Mar 27, 2008 | 12:14 AM
ill have a set of ti retainers and a set of springs here in a day or two hit me up if are interested ill let them go for a decent price
they will handle the rpms there from a daytona prototype car
