valve float??
Old Mar 27, 2008 | 12:23 AM
MikeGyver's Avatar
I think it's detonation. The way you describe it reminds me of mine. Did you retune for the smaller pulley? I would check fuel pressure first, and do a scan to check AFR and KR.
Old Mar 27, 2008 | 12:43 AM
terravast4's Avatar
I did a re-tune for the pulley change and afr was good and made gobs of power with no tuning isues. I also read the plugs and they were clean, a little pinkish white but no glitter from detonation. every plug was identicle.
Old Mar 27, 2008 | 12:49 AM
jkwalkercchs's Avatar
then its the boost reaking havic on the springs u need good springs for high rpm boost applications and go ahead and upgrade to the lifters
Old Mar 27, 2008 | 05:04 AM
03sierraslt's Avatar
I wouldnt worry about the lifters, stock lifters will handle more then that. I would look at doing springs, pushrods and a cam of your choice while you are in there.
Old Mar 27, 2008 | 09:46 AM
Stoichiometric's Avatar
I agree^. How much boost are you making?
Old Mar 27, 2008 | 10:29 AM
TXsilverado's Avatar
im selling some brand new comp 918 springs for 160 shipped. pm me if interested.
Old Mar 27, 2008 | 01:30 PM
PappyDan's Avatar
Tribe Shaman
i don't know how many miles you have on the motor.
your stock springs are not strong enough for your upgrade on boost.
you need a set of stronger springs, LS6, 915, 918, or duel.
like it has already been said, now would be a good time for a cam
and spring swap that will work well with the radix.
Old Mar 27, 2008 | 02:55 PM
There must be some weak springs floating around, mine stock springs held up to 30k miles boosted shifting at 5700 with no problem. (Stock Cam) Not saying its not a good idea to upgrade the springs, because it is.. Just throwing some info out there
Old Mar 27, 2008 | 03:17 PM
my 918's sold...
Old Mar 27, 2008 | 05:59 PM
2ktransam's Avatar
With my stock springs I could hear a change in the engines tone above 5,500rpms. When I put it on the dyno you could see the valve float on the chart and it lost a lot of power quick up top. I installed a $50 set of ls6 springs and now it pulls great up to 6k with no valve float.
