Vacuum Port
Old Sep 3, 2012 | 10:46 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Default Vacuum Port
Sence going back naturally aspirated to make room for future plans . Wondering whats the best way to plug the vacuum port on the passenger side of the intake manifold? nnbs intake btw
Old Sep 4, 2012 | 09:25 AM
Piss Pumps for Sale
no suggestions? Theres a little tab i had to break off to get my vacuum operated guages to work, aswell as wastegate and blowoff valve, looking to just plug it now, got a peice of vacuum hose with a screw in one end and a bunch of caulking around it to plug it, but Im looking for a cleaner more permanent solution, thanks guys
Old Sep 4, 2012 | 10:07 AM
BlownChevy's Avatar
blownerator
25 Year Member
The one on the top is the only Manifold Vac port.
Old Sep 4, 2012 | 10:10 AM
Preston129's Avatar
You tapped a hole in the manifold? If it has a nipple, cap it with a rubber vacuum cap.
Old Sep 4, 2012 | 10:55 AM
nonnieselman's Avatar
Just route it over to the PCV hose goin from the intake to the valve cover. put a T in it and it wont look goofy with a plug on the intake.
Old Sep 4, 2012 | 11:14 AM
Atomic's Avatar
I have a gauge for that
Pic?
Depending on the size of the hole tap it for 1/4npt and put a brass plug in it.
Old Sep 4, 2012 | 12:00 PM
Piss Pumps for Sale
yes its on the passenger side but you are correct its somewhat on top, but the nozzle shaped platic sticks almost straight out horizontally. I cant find a cap thats about the right size, I could tap it for a 1/4 npt fitting and plug that I suppose
Old Sep 6, 2012 | 08:18 PM
green02's Avatar
Pn 41050 in the help section at autozone is where i got my vacuum caps. Like 3 bux i think.
Old Sep 6, 2012 | 08:21 PM
green02's Avatar
That is what i used to cap my vacuum port. Mine is nbs but i think the ports are the same.
dsbodley
Nov 14, 2015 09:46 PM
GMCtrk
18
Oct 6, 2015 03:48 PM
gmcyukon
Oct 3, 2015 11:03 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
lxcoupe
Sep 25, 2015 12:36 PM
