706 Heads with Boost?
Old Sep 7, 2012 | 01:18 PM
Ferocity02's Avatar
Default 706 Heads with Boost?
In a couple weeks I'll be doing my cam, head stud, head gasket swap and was thinking since I'll have the heads off, is there a better factory head out there for my 5.3L than the 706's? I have heard of the 706 castings having cracking issues, especially under boost.
799 heads seem affordable and flow well, and I could have them milled back to stock compression. I guess there are basically the same as 243 LS6 heads.
What about 862 heads? I guess they are the same as 706 but are they more reliable?
Some more info I've found:
https://www.performancetrucks.net/fo...i-have-496592/
http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
Old Sep 7, 2012 | 07:45 PM
If it's in your budget get the 799/243's and dont look back. I'm in the same boat as you. I will just clean up my stock 862's and bolt them back on. I'm planing on running a MPT 70 with 12#. The Castech casting were supposed to be the one's that leaked.
Old Sep 7, 2012 | 08:16 PM
Ferocity02's Avatar
799s are definitely affordable, seen some for under $400. How much do they have to be milled to return to stock compression?
Old Sep 7, 2012 | 09:47 PM
JoeyGC5's Avatar
I think they need to be milled like 0.020-0.030" for return to stock compression. Like I wroye over on Tech, I use the 706 heads (unmilled unported) and I make decent power. I'd love to upgrade to 243/799, AFR 205, or Edelbrock's 190cc heads.
Old Sep 8, 2012 | 12:26 AM
Blown06's Avatar
8 Second Truck Club
Ran the times in my sig with 706's.
Old Sep 8, 2012 | 12:32 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
706's got my 5.3 into the 11's. But if you can get a deal on some 799's, it's worth it.
Silveradorst07
Dec 31, 2015 12:04 AM
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
BigEd_72455
Aug 8, 2015 07:37 PM
