universal intercooler help
Old Oct 23, 2008 | 11:05 AM
gmc6.0's Avatar
Default universal intercooler help
has any installed a universal front mount air-air intercooler on there ride can you send me pcis or suggestions.
Old Oct 24, 2008 | 10:15 PM
RandomHero's Avatar
bumping this up since I'm also interested in an intercooler that will fit
Old Oct 24, 2008 | 10:28 PM
Mangled03gmc's Avatar
Baltimore Whore
John
Old Oct 24, 2008 | 10:43 PM
RandomHero's Avatar
How tall is that? I'm pretty worried about ripping my intercooler off. My truck is lowered almost 5/7 and I pull my valence off all the time.
Old Oct 24, 2008 | 11:43 PM
2ktransam's Avatar
My intercooler looks the same as the one in the picture and it is 12 inches tall. The bottom of the intercooler touches the bottom of the valance so you will have some problems with it dragging.
Old Oct 24, 2008 | 11:47 PM
kbracing96's Avatar
Random, I not sure what you can do with yours other then learn to drive it without ripping the valance off all the time. You really can't mount an intercooler any higher in the older trucks as you can't get the inlet and out let any higher cuz the frame is in the way. I did find a intercooler that is 2" narrower then mine, so you won't need to notch the frame, but I don't know how you would get it any higher...
Old Oct 24, 2008 | 11:53 PM
RandomHero's Avatar
Yea, I've seen your pics and I've been searching through old threads.
As far as ripping off my valence, it's just the nature of the roads I drive. Pretty much everyone back home has a dirt/rock road.
I'm thinking I may try and go with a 9" intercooler rather than a 12". The extra 3" would give me the piece of mind, and I don't plan on running any crazy amount of boost.
EDIT- I see what you're saying now and a 9" intercooler wouldn't make any difference. Hopefully I can figure something out.
Old Oct 25, 2008 | 07:42 PM
Rick_Vor's Avatar
When I did my first Procharger install, I notched the bumper mounts like KBRacing96 for a 24x12x4 FMIC.
It makes a nice, clean install that you can knock out in an afternoon.
When I replaced the Procharger with a couple Turbos, I switched to a 2 into 1 FMIC directly in front of the radiator. Works great and keps the plumbing to a minimum but a bitch to install. Took probably 2 full days to cut, mount and plumb the cold side.
I like the 2nd style better and keeps the spooling time shorter but it's a lot more work than theh 1st one.
Rick
Old Oct 25, 2008 | 08:44 PM
Baltimore Whore
My valance is actually a inch lower then the IC, I had the problem also and since this is the new valance I am going to be extra careful
John
Old Oct 26, 2008 | 10:21 AM
gmc6.0's Avatar
what are your measurements on your intercooler the overall measurments would be nice my buddys giving me one but the core size is 27x12x3 so overall its a bit bigger...
