universal intercooler help
has any installed a universal front mount air-air intercooler on there ride can you send me pcis or suggestions.
bumping this up since I'm also interested in an intercooler that will fit
How tall is that? I'm pretty worried about ripping my intercooler off. My truck is lowered almost 5/7 and I pull my valence off all the time.
Originally Posted by RandomHero
(Post 4032504)
Random, I not sure what you can do with yours other then learn to drive it without ripping the valance off all the time. You really can't mount an intercooler any higher in the older trucks as you can't get the inlet and out let any higher cuz the frame is in the way. I did find a intercooler that is 2" narrower then mine, so you won't need to notch the frame, but I don't know how you would get it any higher...
http://i3.photobucket.com/albums/y57...6/DSCF0041.jpg http://i3.photobucket.com/albums/y57...6/DSCF0037.jpg http://i3.photobucket.com/albums/y57...6/DSCF0055.jpg http://i3.photobucket.com/albums/y57...6/DSCF0035.jpg http://i3.photobucket.com/albums/y57...BOVpics004.jpg http://i3.photobucket.com/albums/y57...BOVpics003.jpg |
Originally Posted by kbracing96
(Post 4032602)
As far as ripping off my valence, it's just the nature of the roads I drive. Pretty much everyone back home has a dirt/rock road. I'm thinking I may try and go with a 9" intercooler rather than a 12". The extra 3" would give me the piece of mind, and I don't plan on running any crazy amount of boost. EDIT- I see what you're saying now and a 9" intercooler wouldn't make any difference. Hopefully I can figure something out. |
When I did my first Procharger install, I notched the bumper mounts like KBRacing96 for a 24x12x4 FMIC.
http://i252.photobucket.com/albums/h...ll50707027.jpg It makes a nice, clean install that you can knock out in an afternoon. When I replaced the Procharger with a couple Turbos, I switched to a 2 into 1 FMIC directly in front of the radiator. Works great and keps the plumbing to a minimum but a bitch to install. Took probably 2 full days to cut, mount and plumb the cold side. http://i252.photobucket.com/albums/h.../FMIC003-2.jpg http://i252.photobucket.com/albums/h...or/FMIC005.jpg http://i252.photobucket.com/albums/h...or/FMIC009.jpg I like the 2nd style better and keeps the spooling time shorter but it's a lot more work than theh 1st one. Rick |
(Post 4032504)
http://i6.photobucket.com/albums/y21...0075/006-9.jpg John |
what are your measurements on your intercooler the overall measurments would be nice my buddys giving me one but the core size is 27x12x3 so overall its a bit bigger...
