Ultimate f/i exhaust?
I've been trying to find the perfect mix between performance and noise control. I daily drive my TVS blown GMC. So far, I've just about decided that if it flows well enough to not cost a whole bunch of hp, it's too damn loud at cruise. Was thinking electric cutouts may be the answer. Maybe use stock mufflers and boost reference the cutouts to open above 4psi. My snow boost cooler starts spraying at 4psi. Maybe there's a way to tie the cutouts into that system?
If someone's done this, please direct me to the thread. Also wondering about the reliability of the electric cutouts. Do they work long term?
The DMHs seem to be pretty good but even they fail, I think youre going to have to end up with a set of dougs brand. Theyre expensive but are much better built. I dont know how you could reference it of boost since all cutouts arent controlled by a moment switch. Id just run a decent exhaust that fits your noise level needs and when you feel froggy hit the button. im going to be running a stock catback and a 3" cutout. I figure most of the time Im not going to need the exhaust open even when in boost, if I really need the extra power I can hit the button.
I would run a bullet and a big magnaflow like a 24" or a 30" or whatever they make.. That should controll it pretty well and straight through.. You might could even throw a cutout in there for the days you wanna wake the dead
I am running LT's, Off road mid pipes into a magnaflow Silverado SS exhaust. Exhaust has two 12" magnaflow round mufflers into one large case magnaflow, single exit behind rear wheel. It sounds great, quiet under normal driving but yet loud enough you know its there. Sounds great at WO no rasp or crackle. All Stainless from headers to exhaust tip. All straight through too.
Right now, I have long tubes leading back to H pipe then dual resonators and then dual Magnaflows. 3" from collectors all the way back. It never shuts up. Don't mind it being loud when my foot is in it, but I'd like a little peace and quiet at cruise. Not horribly loud at cruise, but it gets that way when I tow. Towing, you can't hear yourself think
Are there any specific e cutouts that are better than the others?
. Are there any specific e cutouts that are better than the others?
. '06 gmc VHO, lq9 with a tvs1900 @ 6#, dynatech lt's, dynatech catted mid-pipes into a magnaflow 2 1/2" di/do, (for the built-in X pipe), on back thru stock piping to two 3" X 18" si/so magnaflows out the back. Louder than a "BY-GOD" under any kind of pedal before i did the di/do. but after I put that in it literally killed my SOTP power.
Also, what size dual Magnaflows? Bumpers had a good suggestion if you are running any of their shorty cans.
Last piece, tailpipes? I'm running 3" downpipes > 3" X-pipe > dual 3" Random Technology 18" cans. It was a little loud in the cab but once I added dual 3" tailpipes to the rear bumper, it made it much quieter in the cab.
Rick
GFYS and STFU
I wouldn't suggest the boost referenced cut-outs, you'll burn the motors on the cut-outs, and they open alot slower than you think. By the time your done with your WOT run the cut-outs will have just opened. Usually take about 4 seconds to open.
