Ultimate f/i exhaust?
Old Dec 30, 2010 | 08:59 AM
  #21
Rick_Vor's Avatar
Originally Posted by old motorhead
Now that's interesting. To keep it simple, maybe just use a 5psi spring and reference to boost. Do those things leak or are they pretty well sealed?
I think you would need to add a manual boost controller in the line to the wastegates so they didn't see any boost till a predetermined psi. Wastegates creep open up to the set spring level. A 5lb spring spring starts openning as soon as it sees any boost and is fully open at 5lbs.
On a related note, also add a manual boost controller to your turbo's wastegate. It will help it spool faster by not letting the wastegate see any boost until your max psi.
Rick
Old Dec 30, 2010 | 09:02 AM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Hell Im 25 and I like quiet exhaust, I prefer to bbe able to hear myself think. And for those of us that tow a loud exhaust gets old real quick, so much so Im going back to a stock catback and am just going to run a cutout off the ORY.
Old Jan 2, 2011 | 05:12 PM
  #23
When I first mounted the blower in 2003 I had the stock exhaust and did the following
2004 - Magnaflow Catback - OK good sound not optimized
2005 - Added Shorties - Throatier but not much better in power
2006 - PaceSetter Long tubes - Noticeable better in sound and Power
2007 - Dual 3inch with magnaflow resonators - Too Loud
2010 - Dual 3 inch with a true x crossover pipe and 2 large straight through mufflers. Surprisingly got better mileage probably due to scavaging while not in boost. The x pipe also keeps it quiet in low throttle but turns wild when you turn it up. Ivre read somewhere that the tru x crossover reduces noise by 8 db over an H pipe. Also engine winds up much quicker.
Here's a Clip of the latest at 60% throttle - No drone in cabin
http://s139.photobucket.com/albums/q...I_3971_NEW.mp4
flatblack83
Jan 3, 2026 07:10 PM
blown02408
Feb 24, 2016 04:50 AM
gaps
Oct 15, 2015 02:53 PM
Superman09
Sep 25, 2015 05:55 AM
