Twin Turbo Choice.
I've got two Borg GM4 turbo's from the 6.5TD's from the mid-90's.
I was wondering if they were too small for a mild twin turbo setup or are they too restrictive for an LQ4?
I plan on running a cam and ported heads, done by myself, but don't plan on making more than 400-450HP but would love TT's.
I'm probably best going with one large turbo, but would love to make use of these things.
I used one on a B16a in a 95 Hatchback and it spooled at 3000 rpms..I think they are a T3 with a 57/61 or close..I would run them..should spool quick..could always change them later..I think the link is the same turbo
turbo_RHE-RHF
turbo_RHE-RHF
Thanks RibeiroBJJ!
These are some rough specs calculated by the 6.5TD guys. These are for the GM8 turbo, which is more efficient but not a significant change enough to upgrade over my GM4's.
So it sounds like it will work great for a potential twin turbo swap
I just want boost but with around town, low speed spool up for around town driving and potential towing. I don't want huge peak HP and TQ numbers.
Gm-8
Compressor
Inducer: 53mm
Exducer: 75mm
Trim: 50
blades: 6
A/R:
Turbine
Inducer: 62mm
Exducer: 52mm
blades: 12
A/R: About 0.56, which is around 9cm^2 cross section area housing
Compressor
Inducer: 53mm
Exducer: 75mm
Trim: 50
blades: 6
A/R:
Turbine
Inducer: 62mm
Exducer: 52mm
blades: 12
The only update is that I've put new seals in my 2 turbo's and painted them in high temp ceramic spray paint.
Once I finish my DD project, I might actually have to the time to pull the truck apart and start mocking stuff up....
Thats months down the road, cuz I also have my K5 Jimmy taking up space in my parents backyard, that they probably won't like me keeping it there any longer.
03regcab sierra
20
Aug 3, 2015 12:11 AM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
