Twin intank pump kit?
Old Apr 7, 2008 | 02:46 PM
stock48's Avatar
9 Second Truck Club
Default Twin intank pump kit?
Who on hear sells the stuff to do the twin intank pumps? Thanks, J
Old Apr 7, 2008 | 02:50 PM
53RUSSELL's Avatar
PM Thunder550 he has one installed in his truck.
Old Apr 7, 2008 | 03:21 PM
philntx's Avatar
This isn't a double, but have you seen it?
Claims to be able to support 600-700HP
http://www.thunderracing.com/catalog...vid=3&pcid=166
Old Apr 7, 2008 | 03:32 PM
thunder550's Avatar
High on diesel fumes
I got mine used from another member on the site, but I believe that Racetronix makes the drop-in twin kit complete with wiring and everything. It was a very easy and straightforward install. Idle pressure is about 52 psi. 3 psi in the manifold is about 62 psi, and when the second pump kicks on at 4psi in the manifold my fuel pressure jumps to about 68psi No fueling issues at all on the stock lines and rails.
Old Apr 7, 2008 | 03:45 PM
TG02Z71's Avatar
Is it quiet? My in-line is a noisy little bitch right under the drivers door.
Old Apr 7, 2008 | 03:54 PM
thunder550's Avatar
Yep, sounds just like a stock pump.
Old Apr 7, 2008 | 04:08 PM
02BlueStepside's Avatar
Any issues under 1/4 tank, pressure or other?
Old Apr 7, 2008 | 05:50 PM
thunder550's Avatar
I haven't run it under 1/4 yet...I try to keep it over 3/8 all the time.
5.3Okasai
Mar 9, 2022 01:07 PM
GXPJAY
Feb 13, 2022 08:15 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
thunder550
Oct 8, 2015 04:53 PM
