TVS2300 not making boost
Old Aug 9, 2010 | 03:29 PM
  #51
kbracing96's Avatar
Originally Posted by TurboGibbs
This is what you need. Much cheaper than a 100 mm TB.
http://cgi.ebay.com/ebaymotors/Turbo...Q5fAccessories
Whats crazy is how many of those they have probable SOLD!
Old Aug 9, 2010 | 04:15 PM
  #52
old motorhead's Avatar
I'm thinking the 2300TVS would require two of those. I wonder if they would work better in series or parallel
Old Aug 9, 2010 | 04:29 PM
  #53
jared91's Avatar
Originally Posted by FarmTruc
they were small baby squirrels, i'm sure they weren't causing much of an issue.
if the stock tb was causing a restriction, then yes, the stock box removal didn't help much.
we're probably upgrading to a 100mm tb, 4" tube, customer said joe recommended this.
I'm sure it'll do some good.
LMFAO pics? were they dead??
Old Aug 9, 2010 | 04:36 PM
  #54
Spoolin's Avatar
GFYS and STFU
I wanna see pics of these squirrels!! That's nuts! (no pun intended) Did they crawl in through the wheel well opening I take it?!
Old Aug 9, 2010 | 08:55 PM
  #55
MikeGyver's Avatar
Question:
will it hurt anything, long term, if we leave this hose routed this way?
the valve still works, moves back and forth like it should.
The Whipple's bypass actuator has a port to operate it with vacuum on one side of the diaphragm, and one for pressure on the other. Is the Maggie's actuator like that? Even if it doesn't, if Brian said it will handle pressure, who would know better?
Old Aug 10, 2010 | 09:40 AM
  #56
BigKID's Avatar
I am not sure how the bypass is setup on the Maggies but my KB's bypass is run off a port out of the tub which sees vac/boost. As long as the diaphram in the bypass can handle the positive pressure under boost, I would think it would work better the way you have it setup now.
Old Aug 12, 2010 | 11:12 AM
  #57
FarmTruc's Avatar
Performance Trucks Sponsor
Just an update.
Installed the new throttle body and stock maggie tube and box, i think it helped 1 psi.
Put the bypass valve back to factory routing, lost boost again, so we're keeping the bypass valve on the boost reference side.
I just wanted to see if it was a restriction or bypass issue, guess we know.
Building a simple 4" tube, mafless, with cone filter, gonna see what that does.
so far, boost was 13.1 peak, it actually makes boost at low rpms now, like the old 112 used to. Boost levels out around 12psi now, 11.8 for sure.
truck is feeling much better!
Gadgetized
Aug 21, 2020 03:14 PM
Silveradorst07
Dec 31, 2015 12:04 AM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
lxcoupe
Jul 21, 2015 02:12 AM
