TVS 8-rib question
Old Jan 25, 2011 | 11:19 PM
swift700's Avatar
Default TVS 8-rib question
For you guys running TVS 8-rib pulley setups, is the factory water pump pulley wide enough, and if so, is it positioned the proper distance from the block? If none of the above, what are you using?
Old Jan 26, 2011 | 06:53 AM
kbracing96's Avatar
Yes, it will work just fine.
Old Jan 26, 2011 | 08:25 AM
EVILGMC's Avatar
Yes indeed. Works perfectly fine with my IW kit. Just be sure to weld the pulley.
Old Jan 26, 2011 | 12:32 PM
Preston129's Avatar
What's the deal about welding the pulley? I've read about a couple other people doing that too...does the pulley work itself loose under boost?
Old Jan 26, 2011 | 12:54 PM
kbracing96's Avatar
The pulley is only pressed on and a supercharger can put a lot of load on it. Since it's off set so much the load will push it off if it's not welded.
Old Jan 26, 2011 | 01:01 PM
Preston129's Avatar
Ah okay that makes sense. Is this something that really only becomes an issue at like 10+psi, or would it also be a good idea at low boost as well?
And are a few tack welds at like 12,3,6 and 9 sufficient or do you really want to go nuts on the welding?
Old Jan 26, 2011 | 01:10 PM
05crew's Avatar
r yall saying the stock 6rib water pump pulley is ok to use with a 8rib belt and setup
Old Jan 26, 2011 | 02:16 PM
03sierraslt's Avatar
Yes it is
Old Jan 26, 2011 | 03:04 PM
moregrip's Avatar
what a rush!
yep
Old Jan 26, 2011 | 03:40 PM
BigKID's Avatar
I would like to know the answer to this question too as I will be doing an 8-rib swap soon.
