TVS 8-rib question
For you guys running TVS 8-rib pulley setups, is the factory water pump pulley wide enough, and if so, is it positioned the proper distance from the block? If none of the above, what are you using?
And are a few tack welds at like 12,3,6 and 9 sufficient or do you really want to go nuts on the welding?
