TVS 2300 Cammed 6.2L Build
Old Jan 15, 2017 | 01:56 PM
  #51
shaw_426hemi's Avatar
Got my maggy HD tensioner, going to get it powder coated to match the rest of the engine and get it installed.
Looking at putting on a 3.2" pulley with a IW 10% overdrive crank dampener to start along with the injectors and other pulleys. Still working out the tune in the base setup. Also going to do plugs, thinking 2 heat ranges colder for 10psi+?
Old Jan 28, 2017 | 06:35 PM
  #52
91LT16SpeedFormula's Avatar
Any more progress?
Old Jan 28, 2017 | 07:16 PM
  #53
12secSS's Avatar
You need to weld water pump pulley on or it will spin off under boost, and do not weld it on the motor remove it ...
Old Feb 1, 2017 | 12:57 PM
  #54
Originally Posted by 91LT16SpeedFormula
Any more progress?
Thus far I swapped spark plugs, added ID1000s and got my larger heat exchanger tank installed. 8 rib pulleys are on order and im need to get that tensioner coated and thrown on.
I need to look up the belt length needed for the 10% OD and a 3.2" pulley as well. Just got my tune file back from BBP for the injector and pulley swap. Pics to follow.
Old Feb 1, 2017 | 12:58 PM
  #55
Is this to protect the electrical system? I was not aware of this.
Old Feb 1, 2017 | 01:22 PM
  #56
03sierraslt's Avatar
I am questing you'll need a K081092HD depending on what idlers you have.
Old Feb 1, 2017 | 02:16 PM
  #57
Running the 100mm Metcos
Old Feb 1, 2017 | 03:49 PM
  #58
12secSS's Avatar
Joe, at left coast 32 will send you a water pump nut to cover the welded on WP pulley....don't weld on motor can damage main bearings in motor ,trust me be there done that .
Old Feb 1, 2017 | 03:50 PM
  #59
I have the 90mm ones. Not sure if it will be long enough or not. I run a K081088 with my 2.9 pulley. I think the 1092 would work for you seeing as though you have some wiggle room with the adjustable idler. With a 3.2-3.4 I used to use the 1092
Old Feb 1, 2017 | 04:23 PM
  #60
I am not saying it can't but you lost me on this. How?
