TVS 2300 Cammed 6.2L Build
Old Jan 1, 2017 | 10:10 PM
  #41
shaw_426hemi's Avatar
Anyone got a pulley recommendation for the blower? Just ordered my metco 100mm idlers and im getting ready to order an innovators 8 rib set with 10% over drive. It came with a 3.3" and i was thinking of going to 3.0-3.1 with the 10% OD crank.
Old Jan 1, 2017 | 10:32 PM
  #42
vettelovralexand's Avatar
My truck makes 10 psi on a 2.8 pulley with 10 pct overdrive, so i would think a 3.3 would be fairly similar on a 2300.
Old Jan 2, 2017 | 09:02 AM
  #43
03sierraslt's Avatar
How much boost are you shooting for?
What engine and Cam? That's on the low side boost wise unless you have some cubes or running a 6.0 with a decent cam and 78mm TB.
Old Jan 2, 2017 | 09:58 AM
  #44
Sorry, i always forget mobile doesnt have signatures. Its a aluminum forged 6.2 with 227/242 cam, tvs1900, and it is a 2009 w 87mm throttle.
Old Jan 2, 2017 | 11:19 AM
  #45
Still seams a bit low but hard to say, whats your inlet setup? What LSA is the cam? Sorry just curious.
Old Jan 2, 2017 | 12:39 PM
  #46
Cam is a btr stage 2 blower cam. Its is a 122 lsa with 6 degrees advance ground in. The intake is actually one of the old gmpp intake dry conical filter setups with the tube which came with the roush blower. I do see some 11s on the gauge but id call the number it hits normally a 10.
Old Jan 2, 2017 | 12:47 PM
  #47
Ya that's -9.5 overlap so its not bleeding off there, interesting. I would try to test inlet vac at WO if I were you for the hell of it. Test off one of the ports behind the TB.
Old Jan 2, 2017 | 08:10 PM
  #48
Well i was looking to make as much as i safely can i was thinking 12-13.
Old Jan 10, 2017 | 01:08 AM
  #49
stroker87's Avatar
subscribed!
doing a 6.2 in my truck not sure if i'm going turbo or TVSxxxx
Old Jan 10, 2017 | 07:02 AM
  #50
Metco 100mm idlers came in, beginning of the 8 rib setup. HD tensioner is also on order. Just need to bite the bullet on the innovators west kit as left coast 32 is backordered for months.
