TurboGibb's old setup has a new home!
Old Feb 24, 2007 | 11:00 PM
  #31
duwem's Avatar
What is that thing sticking up out of the downpipe right after the turbo?
Old Feb 24, 2007 | 11:57 PM
  #32
TurboTony's Avatar
I still have not been able to fix the oil burning problem. The only thing I have left to do is replace the valve seals on the driver's side. I have deleted my PCV system completely, sealed all the intake rocker bolts, and run compression and leakdown tests...and replaced valve seals on passenger side, nothing has helped. If the driver's valve seals don't fix it I'm going to try to talk TSP into replacing the heads. I don't know where else the oil could be coming from.
When does it seem to burn oil?
I noticed that the oil feed and drain don't look like they are at 12 and 6 oclock. That could cause a bit of oil to push into the turbine housing and make it seem like it's burning oil. Also be sure to check that all the fittings, hoses, etc on the oil drain are 1/2 ID at the least. A restricted drain will cause the same symptoms.
Tony
Old Feb 25, 2007 | 01:04 PM
  #33
thunder550's Avatar
High on diesel fumes
Originally Posted by TurboGibbs
Man, that thing is bad ***! Who did most of the fab work on it? They are just awsome!
LOL
You forgot the pic of the electric cut out?
I guess I did! Hey did you ever notice a difference when running the cutout other than it being louder? I'm trying to decide if I want to keep it or sell it.
An experiment in pulling PCV vacuum from the exhaust, IIRC...Mark can explain more...
Tony
It's not a turbo issue, it was burning oil before I installed the turbo. I have a whole thread on it here
https://ls1tech.com/forums/showthread.php?t=658813
Old Feb 25, 2007 | 01:54 PM
  #34
kbracing96's Avatar
Looks sweet Chris The only thing I might have tried to do different would have been to have the oil return to the pan above normal oil level, but the turbo is high enough from there, that it will probable drain fine.
PS, I think I have about a 15# spring
Old Feb 25, 2007 | 03:03 PM
  #35
TurboGibbs's Avatar
I basically never ran it with the cut-out open so I dunno. I was going to try back-back runs at the track and dyno.
On the evap in the downpipe, you can screw that check valve out and put a pipe cap on it and it will look cleaner.
I had the drain line 2-3" higher but it should drain just fine where you have it.
Old Feb 26, 2007 | 01:16 AM
  #36
Spoolin's Avatar
GFYS and STFU
What kind of cut-out is it? Doug's headers or butterfly? If it's the former let me know and I'll take it off your hands if it's the right size!
Old Feb 26, 2007 | 07:58 AM
  #37
blown3qtr's Avatar
Thunder 550= turbo550
You gonna sell your lower air dam? PM me if you're interseted. I've been looking to buy a z71 tahoe airdam.
Looks awesome!
Old Mar 1, 2007 | 08:37 PM
  #38
cablebandit's Avatar
9 Second Club
get jim to put a tbrake in that 80e!!
Old Mar 1, 2007 | 11:09 PM
  #39
thunder550's Avatar
Looks awesome!
Thanks! I'm keeping the air dam, gonna put it back on when I have some time to make it fit. I'm getting tired of the truck looking like this.
Don't put ideas like that in my head!!
That's a nice little turbo you got there, BTW..
Old Mar 1, 2007 | 11:11 PM
  #40
thunder550's Avatar
It's a QTP electric....one of my buddies told me he'd buy it if I remove it. I think I'll run it though and see if it makes a difference other than noise.
