Turbo wrap question
Old Mar 27, 2016 | 12:02 AM
AlwaysOnKill's Avatar
Default Turbo wrap question
I'm about to order DEI Tiatianum wrap to wrap my drivers manifold , crossover , Trick manifold and down pipe . About how many feet do I need ? 200ft ? How wide should I get the wrap 2 or 4 inch?
Old Mar 27, 2016 | 12:35 AM
walledition's Avatar
I used 1" on manifold and 2" on the rest of the pipes, dont remember how much
Old Mar 27, 2016 | 11:24 AM
Byrdman11's Avatar
I use 2in on everything and 150ft all do everything. Get a a lot of clamp too.
Old Mar 27, 2016 | 01:54 PM
mdwatts11's Avatar
Used about 40' of 2" on my downpipe yesterday.
Old Mar 27, 2016 | 01:56 PM
FFDP's Avatar
Don't use the clamps that you have to cut the extra metal off, like the ones used on some CV joints. Those suckers will cut your hands up so bad if you have to do any work around them in the future.
GMCtrk's Avatar
You will be amazed at how much wrap it takes.
I wouldn't go any less than 150-200 ft
Old Mar 27, 2016 | 01:57 PM
GMCtrk's Avatar
And as far as clamps, I don't use them. I use SS wire.
Old Mar 27, 2016 | 03:12 PM
Atomic's Avatar
I have a gauge for that
I use big hose screw clamps.
Old Mar 27, 2016 | 06:31 PM
Thank you for all this good info . I'll place my order now .
Old Mar 28, 2016 | 09:07 PM
TimDave217's Avatar
Use safety wire that's all i've ever used and it works perfect and is hard to spot with the eye if going for a clean look, just an extra plus.
