turbo turbine housings
Old Oct 11, 2007 | 07:03 AM
TURBHOE's Avatar
Default turbo turbine housings
ok so i have a t4/t04r turbo. i decided to go a diffrent route with it so i need a t3 turbine housing. can i just bolt on a t3 turbine housing or do i have to change the impellar also?
Old Oct 11, 2007 | 07:22 AM
Lord Aries's Avatar
I think everything is diffirent, including the Mounting flange...
Old Oct 11, 2007 | 07:55 AM
TURBHOE's Avatar
yes the mounting flange is smaller the whole housing is smaller. which is why i want it. they make a t3/t04r and a t4/t04r. i have the t4 but i want a t3 turbine. it will bolt on but i'm not usre if i have to change the impeller or not.
Old Oct 12, 2007 | 12:29 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I'm pretty sure you need to change the turbine wheel too (it would be weird to me if you didn't, but stranger things have happened).
Old Oct 12, 2007 | 07:18 AM
Lord Aries's Avatar
Oh and by the way, according to a friend of mine that works a Speed Shop:
Boys use T3's, Men use T4's... lol
Old Oct 12, 2007 | 08:50 AM
kbracing96's Avatar
A T3 will probable need an O trim wheel to go with the housing where your T4 probable has a P trim, but I'm with the others?!? Why a t-3?!?!? in a single application, it will be quite a restriction unless you want supper fast spool and not a lot of boost, in that case your beter have a larger waste gate, cuz your gona be running most of your exhaust though it.
Old Oct 12, 2007 | 11:29 AM
PPI Typhoon's Avatar
If I have a Q-trim wheel on my T76, but a T3 housing.......can I swap a T4 housing on it?? That would suck if I'm not able to use my turbo on the 5.3.
Old Oct 12, 2007 | 08:45 PM
TURBHOE's Avatar
well because its not for my tahoe. it cost so much to finish getting everything for my tahoe. like manifold then down pipe. fuel system and bla bla bla its like the list never ends. but for my car i can get everything to put this turbo on it for like $300. it already has a high flow fuel pump. i have the injectors already including the injector driver. all i need it the $89 cast iron manifold and a flange for the down pipe and i got basicly everything i need. then my 2300 pound car will fun to drive. its my daily driver for me. its too small for my family now and its paid for. so its ok if it breaks. if the tahoe breaks i'm screwed because its the only ride i have that can fit me the wife and 4 kids.
Old Oct 12, 2007 | 09:46 PM
kbracing96's Avatar
What kind of car?
Old Oct 12, 2007 | 10:16 PM
TURBHOE's Avatar
you don't really want to know. i would have to double up on my flame suit.
yellow2000S/R
Mar 12, 2016 04:33 AM
LSX-81-SIERRA
Aug 31, 2015 05:52 PM
fastjweb
Aug 31, 2015 09:57 AM
08lambochevy
Aug 7, 2015 11:42 PM
05GMC4.8
Aug 7, 2015 09:55 PM
