turbo truck missing above 5400 rpm
Old Sep 28, 2013 | 10:51 PM
walledition's Avatar
Default turbo truck missing above 5400 rpm
im asking this for a friend:
-2004 singlecab
-texas speed and performance engine (dont know the specs)
-jake performance t400 transsmission
-88mm turbo
truck is built recently and it launches great but once about it hits around 5400rpm it starts popping and missing and doesnt want to go above 5400
so far:
-plugs have been changed 2 times
-new msd wires
-tuner said injectors seem like doing good in hp tuners data
-cam sensor and sprockets have been changed
its a well known tuner so i dont think its the tune
any ideas would be appreciated, if any other info needed i can get it, thank you in advance
Old Sep 28, 2013 | 11:05 PM
Ferocity02's Avatar
How much boost?
Stock valve springs?
What plugs and gap?
AFR?
Timing?
What fuel? Meth?
Old Sep 28, 2013 | 11:20 PM
Originally Posted by Ferocity02
How much boost? 20 psi
Stock valve springs? its a built, forged engine
What plugs and gap? i´ll ask my friend will come back to you
AFR? need to ask the tuner will get back to you
Timing? need to ask the tuner will get back to you
What fuel? Meth?
no meth, c16
truck made 1006 rwhp and worked great on the dyno couple months ago, then some times it did this, then worked great again now it will just always do this
my friend just told me he relocated the battery to the rear in the box, could a lose ground make this problem?
Old Sep 28, 2013 | 11:53 PM
Blown06's Avatar
8 Second Truck Club
It could be a grounding issue, but what plugs and what gap?
Old Sep 29, 2013 | 12:30 AM
Three6GMC's Avatar
check your fuel injector duty cycle when it gets to 5400 might be putting in too much fuel. Had that problem with a vette when we added bigger injectors...Scaled them to spec but still had to continue to pull fuel until it started clearing up. It would hit a wall at like 4800 rpm and act like a rev limiter. Think my buddy ended up pulling 80% of fuel and fixed it.
Old Sep 29, 2013 | 10:58 AM
5671a-10 at 20 gap
Old Sep 29, 2013 | 11:45 AM
Atomic's Avatar
I have a gauge for that
Whats the wideband say? Ill never understand why some guys will put in $20k into the engine/trans/turbo but wont buy a $200 gauge to make sire it wont blow up.
Old Sep 29, 2013 | 11:52 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I see a Lingenfelter LNC002 in your sig. Did this problem start after installing it? I think I remember somebody having a similar problem, I'd try removing it.
Edit: just realized you said it's a friend's truck, not yours. Sorry...
Old Sep 29, 2013 | 12:32 PM
Gadgetized's Avatar
I am having a similar issue lately. I was going to check my crank sensor to make sure it is getting a good signal. Is he running a billet reluctor wheel?
Old Sep 29, 2013 | 02:31 PM
Just got some more info:
Air fuel is at 11.5-11.8......
11.8 airfuel. 15 degree timing 80% duty cycle.... 20-24 psi
