Turbo trick help
Old May 5, 2014 | 11:02 AM
TrickTurbo's Avatar
Truck Sponsor
The 76/68 .96 ar will be fine on that engine
Will max out in the 650range.
Spool is fine.
The difference between the 70 to a 76
Is a mood
Point on that size engine.
We need to know the max power you are wanting. That's the important part.
I can build a kit that is at full spool at 2500rpms.
Don't suggest it though.
If its for pulling. Get the 74/75.
If you need more then the Borg 80/83.
Old May 6, 2014 | 07:54 AM
Go5.3tt06's Avatar
Spool is fine.
Is a mood
Thank you for reply. Finish order kit from you trick. Can't wait see kit. Thank y'all for patience with me.
Old May 6, 2014 | 02:52 PM
jtomasik's Avatar
Registered User
Spool is fine.
Is a mood
What turbos do you guys use in your GM Level 3 kit?
Old May 6, 2014 | 04:05 PM
TrickTurbo's Avatar
Truck Sponsor
Magnum or pecision.
76/68. Depending on what I have in stock.
Upgrades to a precision
74/75 or 76/76cea
Old May 6, 2014 | 05:31 PM
Go5.3tt06's Avatar
I'm on stage 3 76mm
Old May 7, 2014 | 12:26 PM
jtomasik's Avatar
Registered User
Originally Posted by Go5.3tt06
I'm on stage 3 76mm
You mind my asking what the numbers are if you had it dyno'd or at the track? How's the power delivery? When's it start to hit?
Old May 9, 2014 | 08:03 PM
Go5.3tt06's Avatar
I wish I know. But it gonna be my first time experience own trick turbo. My goal want 600-650 hp on that. I will find something in future with this experience. Trick is built me in progress 3-4 weeks. It will take a while for me finish the project maybe a year. I need research for fuel system, 4l80 transmission, and drivetrain work. So I able make everything ride perfect and powerful!
lxcoupe
Sep 6, 2017 08:24 AM
TAPyvehc93
Jul 23, 2017 10:54 PM
chvy=power
Sep 8, 2015 11:06 AM
slowswb
Sep 5, 2015 02:27 PM
Jake75
Jul 22, 2015 09:20 PM
