Catch Can with Whipple?
Old Apr 24, 2014 | 09:57 AM
Will's Avatar
Default Catch Can with Whipple?
Alright, so I have searched and looked through several posts and see that guys are using various brands of catch cans and just putting them in between on the stock system, but I haven't been able to find anyone that is using one with the older style side-mount whipple.
The issue is that the side mount requires the valve covers to be swapped and so the PCV side is now on the passenger side and the fresh air tube is on the driver's side.
Question is do you guys think that would matter as far as just putting a catch can in the middle of the stock system?
Next question, I have seen some cap off the fresh air side and vent the fumes to the intake tube before the TB. What is the best way to put it in line when it comes to FI?
Lastly, what is the best brand?
Old May 10, 2014 | 10:31 AM
Will's Avatar
Anyone?
Old May 10, 2014 | 02:46 PM
GRRR65GTO's Avatar
Really any catch can will work, the point is to catch the oil coming out of the crankcase from the blowby. What you could do run both valve covers to the catch can and then run a line from the can to before the throttle body if you dont want the oil smell. On my truck I have both covers to a can that is vented to the atmosphere and you can only smell it if the truck is running and the hood is up,and its not that strong of a smell
Old May 10, 2014 | 03:22 PM
Will's Avatar
So, I already bought a Moroso catch can which only has two connections for two hoses. The way Moroso says to hook it up is one hose to intake and one hose to valve cover, but my question is what about the other valve cover?
The PCV valve side is to vent the engine or is it the passenger side that vents?
Old May 11, 2014 | 09:44 AM
GRRR65GTO's Avatar
So run both valve covers to the catch can and get a y to join them then run it to before the throttle body
Lthompson
Oct 2, 2015 12:45 AM
nic351
Sep 24, 2015 09:43 AM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
