Turbo trick help
The 76/68 .96 ar will be fine on that engine
Will max out in the 650range.
Spool is fine.
The difference between the 70 to a 76
Is a mood
Point on that size engine.
We need to know the max power you are wanting. That's the important part.
I can build a kit that is at full spool at 2500rpms.
Don't suggest it though.
If its for pulling. Get the 74/75.
If you need more then the Borg 80/83.
Spool is fine.
Is a mood
Spool is fine.
Is a mood
Spool is fine.
Is a mood
Spool is fine.
Is a mood
Spool is fine.
Is a mood
What turbos do you guys use in your GM Level 3 kit?
I wish I know. But it gonna be my first time experience own trick turbo. My goal want 600-650 hp on that. I will find something in future with this experience. Trick is built me in progress 3-4 weeks. It will take a while for me finish the project maybe a year. I need research for fuel system, 4l80 transmission, and drivetrain work. So I able make everything ride perfect and powerful!
lxcoupe
Sep 6, 2017 08:24 AM
