Turbo Tow Rig
Old Sep 10, 2013 | 03:25 PM
  #51
Vortec350ss's Avatar
Cool build! You got some skills!
Old Sep 10, 2013 | 08:36 PM
  #52
carfreak07's Avatar
Old Sep 22, 2013 | 04:29 PM
  #53
Denali08's Avatar
Thanks for posting ur external pump setup. Is that fitting at the back of the tank bolted from inside or just threaded to the plastic tank? What size is your inline feed line and fittings?
I'm going to install my Magnafuel inline fuel pump but afraid to drill the tank and end up with fuel leak. So, can you explain how you drilled the tank and fixed that fitting?
Old Sep 23, 2013 | 09:45 AM
  #54
69Camaro427's Avatar
I love that rev limiter pop shifting into second haha sounds dirty. Awesome build man!
Old Sep 29, 2013 | 09:01 PM
  #55
carfreak07's Avatar
It's threaded into the tank, I used a unibit and then just tapped it. Applied thread sealant, the tanks are very thick so you won't have trouble, make sure to get all the shavings out from inside though. The feed line is 3/8" I believe. Make you hole on the small side so your fitting does not bottom out. You want it to start tightening up in the threads pretty early to retain a tight seal!
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Oobray
Jun 13, 2022 03:38 AM
Zizzle
Oct 19, 2017 08:44 PM
Raggedz71
Jul 29, 2016 10:20 AM
2500ZL1
Jan 25, 2016 06:30 AM
