Turbo temperature question
Old Sep 14, 2010 | 05:35 PM
THE-HOE's Avatar
Default Turbo temperature question
Im curious to what might be the correct (normal) operating temperature that the turbo should operate at. I have my Pyro hooked up into the manifold before the turbo. ( KB kit)
My 6L idles at 800 Degrees and i have seen as much as 1400 degrees under heavy load and higher boost. It is around 1200 on lower boost. Just wanna see if that's normal. Thanks in advance
Shane
Old Sep 14, 2010 | 05:36 PM
A Low Dime's Avatar
13 Second Truck Club
Exhaust housing or inlet housing? Both? center section?
Old Sep 14, 2010 | 06:35 PM
JakeBrakeIH's Avatar
Mine pretty much reads exactly the same. I have my probe right before the charger.
Old Sep 14, 2010 | 06:37 PM
THE-HOE's Avatar
I meant for the people that have an EGT gauge hooked up before the turbo on the log.
Old Sep 14, 2010 | 06:38 PM
THE-HOE's Avatar
Okay, that makes me feel a little better. Some guy was telling me that that's way too hot, but he really wasn't a guy i would trust. He was probably thinking about diesel engines, I believe that they have lover EGT's
Old Sep 14, 2010 | 07:09 PM
Diesel's tend to have lower EGTs while idling or light loads but depending on the set-up they will get much hotter than 1400 at WOT lol.
Old Sep 14, 2010 | 07:13 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Low load areas diesels are cooler but a hot tune on a single charger being pushed hard can hit 2000 on a long pull, most "hot" diesel tunes will hit 16-1800*s.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
08lambochevy
Aug 7, 2015 11:42 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
