which turbo size? gearing? and stall?
Old Jul 15, 2012 | 12:06 AM
Not a Clone SS's Avatar
Registered User
Default which turbo size? gearing? and stall?
shooting for 500awhp, I'm going to be running a rear mount, so I've been looking at a 70mm .81 A/R from magnum, 10psi should bring me close to 500 to the wheels, I'm looking for the quick spool, 10psi should be hitting a lil bit after 3k? i have 4.10's now on a 31.91in tire and ill be getting smaller ones that are 29.74in so whatever my gear ratio is? on a 2800 stall. this setup should be good for dd'ing?
Old Jul 15, 2012 | 08:39 AM
Beatdown Z's Avatar
Laid Back
Everything sounds good to me. I'm assuming your're running an LQ9. If that's the case, then you could prob go a little larger with the turbo and still have it spool quick. 4.10's with 30" tires and the 2800 stall will work great with your heavy *** truck.
Old Jul 15, 2012 | 01:41 PM
Registered User
ok thanks man, i was thinking maybe a 72 with a .81 A/R?
Old Jul 15, 2012 | 10:12 PM
Silverad0 SS's Avatar
Yeah 72mm .81 will have a quick spool to it, and will leave you room to grow
Old Jul 18, 2012 | 09:22 AM
Registered User
T t t
Old Jul 18, 2012 | 01:19 PM
nonnieselman's Avatar
I ran a Masterpower 76 qtrim on a rear mount with my LQ4 and it spooled decent. its been years ago so cant really give you much details.
Now my buddy that has a isky 212/114lsa 5.3 in a 98 rc has a 76mm qtrim magnum and it spools fast with a 4L80E / 3000 converter from a roll.
From a dig it does take a second to get goin but has a mean top end.
Old Jul 18, 2012 | 03:38 PM
Registered User
thats cool, I'm looking for the quick spool with my low gears i don't have much of a top end like 130-140 I'm wanting to get the most out of the awd but thanks for the info
Old Jul 18, 2012 | 04:58 PM
quicksilverado's Avatar
The 4.10 will not load the turbo well and it will have more lag.
Old Jul 18, 2012 | 05:42 PM
Registered User
yeah but i need them, i got almost 6000lbs i gotta move, so maybe the smaller turbo 72mm and the smaller A/R .81 will help?
Old Jul 18, 2012 | 05:48 PM
Registered User
and it is a lQ9
