which turbo size? gearing? and stall?
shooting for 500awhp, I'm going to be running a rear mount, so I've been looking at a 70mm .81 A/R from magnum, 10psi should bring me close to 500 to the wheels, I'm looking for the quick spool, 10psi should be hitting a lil bit after 3k? i have 4.10's now on a 31.91in tire and ill be getting smaller ones that are 29.74in so whatever my gear ratio is? on a 2800 stall. this setup should be good for dd'ing?
Everything sounds good to me. I'm assuming your're running an LQ9. If that's the case, then you could prob go a little larger with the turbo and still have it spool quick. 4.10's with 30" tires and the 2800 stall will work great with your heavy *** truck.
I ran a Masterpower 76 qtrim on a rear mount with my LQ4 and it spooled decent. its been years ago so cant really give you much details.
Now my buddy that has a isky 212/114lsa 5.3 in a 98 rc has a 76mm qtrim magnum and it spools fast with a 4L80E / 3000 converter from a roll.
From a dig it does take a second to get goin but has a mean top end.
