Turbo size advice for 408
#31
I run a 1.30 A/R on-center hot sided T76 on my tow rig (very mild 393). It's an old turbo and crotchety compared to the GTS-series stuff. It's making somewhere around 850 crank hp based on weight and ET. I leave at about 4 psi and see about 18 psi peak. Friend of mine is making about 1200 crank hp on a tangential housing small frame T88 on a 408.
I'm personally not a big fan of a T70 because of the peak efficiency pressure ratio, though I understand that the Holset T70 has a different map than that Garret T70.
I personally think the optimum turbo for a fairly large displacement gas motor with moderate power goals is a .96 A/R GTS or GTSH series 76 because it will move a lot of air at relatively low pressure ratios.
#32
nice info. any comparisons on front mount cam swaps?
we did a swap from a stock 5.3 cam to an 01 z06 cam and gained 100rwhp at the same boost level. no spool time info though since we have a 5000+rpm stall. we got such killer results we had to ask ourselfs how much a 02+ cam would help or an aftermarket grind.
might have to do some serious cam swap dyno thrashing on our next project.
#33
I would put an S400 on your 408. THis is a great turbo and is only $585. I can't post the link though because Majestic Turbo isn't a sponsor here.
#34
#35
R
FlowmasterMufflers
Jul 30, 2015 05:03 PM
