Turbo size advice for 408
Old Dec 5, 2007 | 10:33 AM
thunder550's Avatar
High on diesel fumes
Originally Posted by zippy
I agree with two of ya'll. An S85 or bigger is what I'd go with. A 408 should have an 88mm turbo or bigger if you use a standard turbo. A T76 is more of a turbo for a 6.0L.
I am very happy with my PT76 on my 408. I think anything bigger would be too big for a street driven truck.
Old Dec 5, 2007 | 11:49 AM
SRT10KLLR's Avatar
Former Vendor
I think the Garrett GTS-76 or Turbonetics TC-76 is what I will be going with since the truck will be run 80% street 20% track.
As for the cam I have no idea what the numbers mean but they are in the first post. It is supposed to be a turbo cam.
Now I need to start a post for some fuel system help.
Edit: What A/R should I go with if using the 76 in rear mount form?
Old Dec 5, 2007 | 08:03 PM
8ALTNG's Avatar
I love how my truck drives on the street. It is mild as can be when crusing, but once I step on it its lights out and the tires are up in smoke. I guess it is all in what you are looking for.
Old Dec 5, 2007 | 08:22 PM
thunder550's Avatar
That's exactly how I would describe mine. I guess I'd have to go for a ride in yours before I could judge.
Old Dec 6, 2007 | 06:59 AM
zippy's Avatar
A 76 should spool up real quick on a 408, but with anything other than low boost you'll work out of the turbo's efficiency range pretty quick.
Old Dec 6, 2007 | 04:43 PM
DrTurbo's Avatar
LS1TECH Sponsor
A TC76 would be the quickest spooling of the bunch and still support pretty big power. Above that then you might want to think about the ST series units instead of making a jump to the full on S-series unit.
Old Dec 6, 2007 | 08:19 PM
Spoolin's Avatar
GFYS and STFU
I think the S85 would be great if it were a front mount but a 76 would work better being that it will be a remote/rear mount.
Old Dec 7, 2007 | 06:57 AM
zippy's Avatar
What about an S78?
Old Dec 7, 2007 | 10:03 AM
DrTurbo's Avatar
LS1TECH Sponsor
What about an S78?
You could always do an ST78 or ST80. They are T4 flange units and will spool quicker then the larger turbined S-series and SX-series.
Old Dec 7, 2007 | 11:25 AM
zippy's Avatar
Yeah, but would an S78 have much spool time issue on a 6.7L? Just asking, not knocking what you're saying. You're Jose' correct?
