Turbo set-up question
Well I bought this kit off a friend and have a few questions on some holes it has open. I pretty much got everything figured out just don't know what these openings are for or were do they go to. Can anyone help? I circled them in red on the images. This will be going on a 2006 Silverado 5.3
The Full kit
On the WasteGate
On the Blow-Off Valve
On the pipe that runs to the Throttle body
The Full kit
On the WasteGate
Wastegate port goes to a pressure only source, like the turbo compressor outlet. Some will say a pressure/vacuum port also work, depends on who you ask.
BOV port goes to boost/vacuum port, probably the top one. Not sure what the bottom one goes to. Atmosphere?
BOV exit just goes to atmosphere.
The threaded bung in the pipe is probably for a intake air temp sensor, or maybe meth injection? Not sure on that one.
How would you connect them to the Vacuum tho?
any port on the intake manifold will work, there is one with a tab on it from the factory that just has to be torn off to use. I also use the top port where the pcv valve is normally vented to. The bung in your cold pipes is to thread an IAT sensor in, run the two wires to the IAT wires included in the maf harness and splice in there.
