Turbo Selection for Trick Performance Kit
Old Mar 10, 2015 | 08:09 AM
Mike1992's Avatar
I'm putting together a turbo kit using Trick's exhaust piping/cast manifold and have been eyeballing Turbonetics turbo's due to cost. For around $800 I can get the either the 72mm with the smaller .81 ar housing or go with the larger 76mm with the .96 ar housing. This is a bone stock 5.3l with a 4l80e behind it. Will be a low boost 6-12 psi truck shooting for 500-600 whp Suggestions?
Old Mar 10, 2015 | 09:45 AM
ncarmy88m's Avatar
Go with the 76mm you will be happier in the truck with that then the lesser turbo power won't be an issue either you should be right in the 5-600 range with that setup with a good tune and stable fuel system.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
chopperloco
Jul 10, 2016 10:45 PM
Silveradorst07
Dec 31, 2015 12:04 AM
cbhedrick
Jul 20, 2015 10:12 PM
Cowboy17
Jul 9, 2015 08:22 PM
