Down pipe construction
Old Mar 5, 2015 | 07:05 PM
hvactech08's Avatar
Default Down pipe construction
I am getting close to building my truck for my s475 1.32 turbo build.
I have a question to the down pipe design. How far back should I go with 5"??
I thought about a elbow out then make a long transiston to 4". Then down the back of the truck. Let me know what y'all do and think
Old Mar 5, 2015 | 07:10 PM
08DenaliT's Avatar
Why step down if your alrdy going 5 inch go 5 all the back.
Old Mar 5, 2015 | 07:30 PM
sum guy's Avatar
That's a huge freakin pipe. Making me think twice about running a bw. What if you run a short section of 5" with a cut out that you can uncork for track duty and y it into 3" or so the rest of the way back.
Old Mar 6, 2015 | 10:09 AM
kbracing96's Avatar
I step them down right after the outlet to 4" No need to try and squeeze an overly huge down pipe when 4" will easily flow for well over 1000hp.
Old Mar 10, 2015 | 01:02 PM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
i remember reading somewhere that about 18" of 5" was needed before transitioning to 4" but im not sure if that was a load of crap or not. it came from a very reputable source tho which makes me wonder.
Old Mar 10, 2015 | 03:17 PM
TrickTurbo's Avatar
Truck Sponsor
5" just matches the casting.
No need for it on that turbo.
Old Mar 10, 2015 | 05:14 PM
kbracing96's Avatar
The 1.32 ar housing has a 96mm turbine so that's a 3.75" wheel. 4" is all the down pipe you need for that wheel.
Old Mar 10, 2015 | 07:06 PM
Atomic's Avatar
I have a gauge for that
I ran a 5" pipe, and if I had to do it again I would just use a 4", same power really. Spool may be a little better on the 5" but thats it.
Dumping out the fender made it spool 2x as fast, but still didnt help overall power.
03sierraslt
14
Oct 9, 2015 05:53 AM
JordanH
Oct 3, 2015 03:59 PM
BlownHD
Oct 3, 2015 12:24 PM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
