Turbo or S/C for 6.2L? Questions...
Old Aug 19, 2010 | 08:31 AM
  #81
Quik's Avatar
5 year bitches!
some trucks have a adapter that was orignally from a vette. this is what you tap. using a 1/8 npt. the adapter is cheap if you had to buy it new
Old Aug 19, 2010 | 08:56 AM
  #82
fasterthenyou's Avatar
My truck has an external oil cooler stock... Would it have the adapter Plate? If not I would rather purchase an adapter plate pre made/ tapped that all I would have to do is screw it on, the filter on it and then an 1/8 NPT to -4 adapter fitting to the port..
Old Aug 19, 2010 | 09:23 AM
  #83
Quik's Avatar
5 year bitches!
Oil cooler trucks don't use it. You'll have to replace cooler with this adapter
Old Aug 19, 2010 | 09:25 AM
  #84
Spoolin's Avatar
GFYS and STFU
Might want to take a look at a thread in the project section called "twin turbo 434LSX" or something to that effect. The kit used is made by Rick, might give you some ideas on how to route the turbos and oil lines.
Old Aug 19, 2010 | 11:21 AM
  #85
O so I will have to remove my oil cooler completely?
Old Aug 19, 2010 | 12:18 PM
  #86
Quik's Avatar
5 year bitches!
Yea unless you go thru alot of hassle or tap oil from another port which isn't as easy as method stated
Old Aug 19, 2010 | 12:46 PM
  #87
smokeshow's Avatar
Mod with training wheels
there is a member on this site that has the inlet of the turbos on the inside {opposite of me]. to me this is an issue as the two turbos are drawing air against eachother [think of tug o war]
Originally Posted by fasterthenyou
That's what I was talking about but air filters in dif location... So as not to fight each other...
If you think the turbos are going to be fighting each other by having the filters a few inches closer, then you're dead wrong. That would assume you're saying the turbos will flow so much air that the space in between them will experience a vacuum relative to atmospheric pressure.....not gonna happen. Who sold you that bullshit information?
You need to worry about flow characteristics inside your charge piping, not out... Put the filters however you want.
Old Aug 19, 2010 | 12:56 PM
  #88
BlackGMC's Avatar
Resident Retard
so what your saying is the probability of an artificial BlackHole being created under the hood during full boost is not a likely possibility?
Old Aug 19, 2010 | 01:01 PM
  #89
smokeshow's Avatar
Hm, on a scale from 1 to absolutely not......you fill in the rest. lol
Old Aug 19, 2010 | 02:00 PM
  #90
Ok so I shouldn't have to tap anything... It should already have a tapped port that was connected to the oil cooler correct. Like a sandwich adapter...
Can anyone with a factory oil cooler take a pic of where the oil
cooler is tapped in to?
Thanks
