Turbo or S/C for 6.2L? Questions...
Old Aug 20, 2010 | 08:14 PM
  #111
Quik's Avatar
5 year bitches!
Maf is ditched this isn't a Ford with crappy pcm
Old Aug 20, 2010 | 08:16 PM
  #112
charcold-bowtie's Avatar
word, i love my OLSD for the last 3 years.
Old Aug 20, 2010 | 09:04 PM
  #113
fasterthenyou's Avatar
OK So just the MAP Sensor... how many bar? and where to get it.. i searched all around and got a part number for a 3bar bosch one but i dont know where to get it or if its the right one...
Old Aug 20, 2010 | 11:54 PM
  #114
Spoolin's Avatar
GFYS and STFU
300 questions...
Old Aug 21, 2010 | 08:03 AM
  #115
Quik's Avatar
5 year bitches!
bar depends on your power goals. i prefer the 3 bar some like the 2 bar cause of resolution but that can be made back up as well.
Old Aug 21, 2010 | 08:30 AM
  #116
Originally Posted by Spoolin
300 questions...
probably sorry like I said I have been a ford guy in the past just trying to learn before I start this venture so I have everything planned out
Old Aug 21, 2010 | 08:38 AM
  #117
Quik's Avatar
5 year bitches!
only way to learn is to ask and read
Old Aug 21, 2010 | 03:36 PM
  #118
I agree.
I've searched and read that most are running 60lb injectors but I haven't seen how much power those can support? Should I just start with the 80lbs and call it a day so they can grow with me when I do need all of them?
Old Aug 22, 2010 | 01:02 PM
  #119
I found a set of 72lb Flow Matched injectors for $325... Probably going to go with them.
Here is my parts list as of today broken down into hot side/ cold side/ fuel/ oil...
I dont know where to get a 3bar MAP Sensor for my engine so I am missing that but everything else is pretty accurate!
What kind of gaskets/ gasket maker are yall using on the connections?
Old Sep 5, 2010 | 05:14 PM
  #120
2004SSS's Avatar
imo here is a better option to ditiching the dam oil cooler , this is the piece you get with the vortech oil feed. it still allows to use the oil cooler which imo on a turbo vehicle cant hurt since the turbo is also increasing the temp of the oil and ditching the cooler will also increase the temp of oil . so this way you can you can have a little more piece of mind without having to go with a thicker oil .
you use two of the oem gm oil cooler gaskets(must be the one with two round holes rather than the one for trucks without a cooler and one oblong hole)
http://www.vortechsuperchargers.com/...20-015v5.0.pdf
its on page 25/58
