Turbo question
Old Dec 29, 2012 | 06:51 PM
BUTTERB30's Avatar
Default Turbo question
So im almost done with hooking everything up on this low mount setup.MUST say so the biggest prob so will be my down pipe is lower than the tranny cross member but ill figure that out some how. BUT my question is i still have two unconnected o2,s for the rear so what do u do with them just disconnect them or what. and will the truck run till i can get it programmed.
A FEW PICS
Attached Thumbnails Turbo question-img_20121229_121556.jpg   Turbo question-img_20121229_121612.jpg   Turbo question-img_20121229_121631.jpg   Turbo question-img_20121229_121643.jpg
Old Dec 29, 2012 | 06:56 PM
GMCtrk's Avatar
Just remove them and have the rear o2 sensor fault turned off in the tune.
Old Dec 30, 2012 | 04:47 PM
TrickTurbo's Avatar
Truck Sponsor
How is your dp lower then the crossover?
You loose the 2 rear o2's.
Old Dec 30, 2012 | 04:52 PM
BUTTERB30's Avatar
ILL be honest RICK im still trying to figure that part out. everything is bolted and turned the right way and i cat go up any further with the exhaust cause its just about touching tranny
Old Dec 30, 2012 | 05:22 PM
TrickTurbo's Avatar
Truck Sponsor
You'll need to rotate your center section a little. So the drain is aim downward asynchronous as possible.
Old Dec 30, 2012 | 05:45 PM
BUTTERB30's Avatar
OK ILL double check it tomorrow AT work thank YOU
5.3lSilverado
25
Aug 29, 2016 12:48 AM
08lambochevy
Aug 7, 2015 11:42 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
