Turbo Kits
Old Nov 13, 2015 | 09:10 AM
VETTEKILR53's Avatar
Default Turbo Kits
Probably a very frequent question. I pulled my House Of Boost Dedicated Drive D1 setup in favor of a single turbo. I need 50 posts to post my blower kit for sale, so im going to use them to ask a few questions... Anyone had luck with the on3 setups for a NNBS? thinking of buying their kit with a 78mm and tailoring it for mu needs. possibly a shorty header of the drivers side instead if the stock mani so it looks good, truck already has a built 5.3, it a 2013 RCSB so its a 6L80, may have to re stall the converter also. Anyone went from a blower straight to a turbo to help with the stall specs?? Thanks in advance for the info.
Old Nov 14, 2015 | 01:08 AM
67goatman455's Avatar
my buddy here is Wichita, ks has an on3 kit on his 4.8l 2007 rcsb. he mentioned something about buying a shorty header from them for the driver side as well, i think thats the route he went. He blew the transmission up on the dyno trying to get it tuned and has yet to get it fixed, so i dont know what he plans on for a stall.
Old Nov 14, 2015 | 11:22 AM
92SS Wagon's Avatar
I've been looking at this kit for awhile as they are in Ohio so I could drive and pick it up. They still don't have all the piping in for this kit. That was on Thursday so patiently I wait
Old Nov 17, 2015 | 02:20 AM
superbee's Avatar
Yeah put an older gen kit on the 07-13 truck. Not bad for a cheap kit. Had to machine a few aluminum blocks and get longer bolts for the sway bar mounts to allow the crossover pipe to clear sway bar, the pass side turbo header/merge piece wont clear the strut tower so you have to man up and notch the strut tower with a death wheel. Bought an aluminum maf flange and got tig'd onto one of the aluminum intake pipes, you have to cut out the hood latch braces and weld in tabs to hold the intercooler up front. Exhaust downpipe doesnt fit the great so if you want full exhaust you definatly need more bends and then weld it up.
Ac to turbo clearance is not good, you will have to cut out a little bit of battery tray and then tweak the lines so it fits in that area and off the turbo, You will also need to get some 90 degree elbows and some heater hose and redirect the heater core lines.
Theres some more stuff, def not a bolt it kit but can easilly be knocked out and can make some decent power. The one we did put down 550 to the wheels at around 12 psi which is good enough to spin stock tires up to 50-60 mph heh
Old Nov 17, 2015 | 04:46 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Damn sounds like alot of work ^^^^ Just get a Trick or KBRacing kit and be done. I know on3 said they would revise their kits but Trick and KBRacing have it down to a science.
Old Nov 17, 2015 | 04:51 PM
ezdaar's Avatar
Or just wait and get the proper kit, instead of forcing a incorrect kit to fit.
Seems logical.
Old Nov 17, 2015 | 06:18 PM
WICK3DxGATA's Avatar
just recieved my on3 kit for nnbs truck last week. dont have it on yet but hopefully will have it on in the next few weeks.
Old Nov 17, 2015 | 08:55 PM
superbee's Avatar
let us know how it goes!!!
i swear those guys at on3 must work 2 hour work weeks jesus.
Old Nov 18, 2015 | 03:09 PM
Yeah they took alot longer than was first told. Something about the cold side pipe. But luckly I was in no hurry to get the kit in since I wouldn't be able to really work on it till winter break.
I will be starting a build log for it and try to get as much pictures as possible of the install and let everyone know how it goes.
$A_Money$81
Mar 27, 2023 10:25 AM
drummer0415
11
Oct 24, 2015 08:16 PM
lt1z350
Sep 28, 2015 12:20 PM
sTNT971
Sep 26, 2015 06:27 AM
GM1697
Sep 9, 2015 01:52 PM
