What meth nozzles do you run
Old Mar 14, 2014 | 07:51 PM
timmay208's Avatar
Default What meth nozzles do you run
Just curious to see what everyone is running for meth setups and what size nozzle/nozzles
Im picking up a snow kit, thinking about doing 1 10gph or 15gph nozzle, having it come on at around 4lbs or so
MY AIT sensor will be right at the top of my charge pipe before it goes into the T/B, will it be an issue to spray say 12-15 inches before that? or is it better to be closer?
Old Mar 14, 2014 | 08:33 PM
03sierraslt's Avatar
I have a single 15GPH on a Alky control kit.
Old Mar 14, 2014 | 08:35 PM
BlackGMC's Avatar
Resident Retard
I have 2x7s. When i go up to 12-14lbs i am going up to 2x10s
Old Mar 14, 2014 | 08:43 PM
timmay208's Avatar
yea im only planning on being 10-12lbs of boost but we dont have alot of 93 pumps out here so i figure it will be a little safer.
thinking about doing a 8lbs pump tune no meth then have another tune setup for 10-12lbs with a single nozzle
where are you turbo guys mounting your nozzles
Old Mar 14, 2014 | 09:04 PM
Ferocity02's Avatar
I have 2x7's also. I tested it and together they do about 15gph with the pump on full. I have it start coming on around 2psi and full at around 12psi, 50/50 water/methanol.
My nozzles are in the charge pipe about 2' before the TB, IAT sensor is in the intake manifold where the EGR pipe went.
I think running two smaller nozzles is better than one big one for more atomization.
Old Mar 15, 2014 | 12:33 AM
timmay208's Avatar
yea i thought about that also doing 1 just after the intercooler and one about another foot after that
Old Mar 16, 2014 | 04:16 PM
black4.8's Avatar
12 and 14gph devils own nozzles. 1 post intercooler and one foot from tb. both are pre iat sensor.
Old Mar 16, 2014 | 07:00 PM
TIM Z's Avatar
11 sec. Truck Mod
Ditto , this is what the man , Julio Don advised .
Old Mar 16, 2014 | 07:22 PM
timmay208's Avatar
good info guys
Old Mar 16, 2014 | 07:52 PM
Pocket's Avatar
Two 12's from DO at the SC inlet
