Turbo guys, update
Old Nov 10, 2008 | 09:39 PM
ZO6Ted's Avatar
Default Turbo guys, update
Well, I put a manual boost controller on today and a retune. Not done, but it's all I can do till business improves. Locked in 2nd, ran from 2k up to about 6200 and saw 15 to 17lbs to start and gradually fell back to about 9lbs. It had rained and I know my exhaust wrap was soaking wet. Just wondering, is it the 8 lb spring in the 38mm wastegate or something else. Maf is way overworked and we will change to a 100mm soon. Ideas? Truck is a helluva lot faster though. BTW, brake boosted to 15 lbs 3 separate times, no breakage. I think this is gonna be fun!
Old Nov 10, 2008 | 09:43 PM
Stoichiometric's Avatar
What type of boost controller did you use?
Old Nov 10, 2008 | 09:48 PM
ZO6Ted's Avatar
Hey, I'm an air conditioning guy, beats me. Got it new for only $50 from my builder, just trying to help me get it running better...little silver sucker with a **** and + - arrows on top. Yeah i'm stupid.
Old Nov 10, 2008 | 09:53 PM
That's OK. I just ask because that may be the cause of your boost dropping off. Also, I wouldn't do the 100mm MAF. The restirction is minimal when you push through the stock MAF, and once you reach the hard limit in the PCM the 100mm can't buy you any more room in the pcm table. Speed density is your next move.
Old Nov 10, 2008 | 09:58 PM
ZO6Ted's Avatar
Kept blowing off the silicon coulping at the MAF. They figured that it was too restrictive. Also the tuner had to tune it SD but without the aid of a 2bar. It was alot of trial and error to get the afr in the right range.
Old Nov 10, 2008 | 10:00 PM
Who's tuning it if you don't mind saying?
Old Nov 10, 2008 | 10:06 PM
ZO6Ted's Avatar
Just a local guy named Matt.
Old Nov 10, 2008 | 11:52 PM
charcold-bowtie's Avatar
move to sd. People have blown their mafs in half on here, now that restiction.
DO u keep a wideband on the truck.
Old Nov 11, 2008 | 07:25 AM
ZO6Ted's Avatar
Yes sir.
Old Nov 11, 2008 | 02:34 PM
05stepside's Avatar
hey ted can you pm your new builder and or shop? im lookin around for a new person to go to since our old one vanished
