Turbo gauges?
Old Apr 11, 2014 | 12:03 AM
  #21
oakley6575's Avatar
Originally Posted by So.cal Wrk Sled
GMCTRK, I think you pretty much nailed it and hate clutter as well. So here's what I'm going to start with wide band and a boost gauge for now. I talked to my tuner and he made a comment as well on failsafes made up in tune and said "don't worry he's got me covered".
Btw:JUST GOT MY KIT TONIGHT!!! Its xmas time. I'm going to start build thread tomarrow. Finally!!
The problem is that just because your tuners "got you covered", doesn't mean your engine can handle the amount of boost it might climb to in an overboost situation. Even though fueling might be safe doesn't mean it can swallow 30psi without harm.
Old Apr 11, 2014 | 12:05 AM
  #22
So.cal Wrk Sled's Avatar
Originally Posted by GRRR65GTO
So youre thinking of doing something like the new camaros have?
Here's my goal I'm trying to keep interior as stock as possible or limit the holes and cuts. Im aiming for that stock factory look or placement of anything I do to interior.
Old Apr 11, 2014 | 12:14 AM
  #23
I agree with you and like I asked what is a must have and I think every one has said wide band as the must have. Now let's move on to the install. It's gear head heaven at my house right now...
Old Apr 11, 2014 | 07:33 AM
  #24
Choda's Avatar
I have boost, a/f ratio, fuel press. all in the a pillar and looks good and very functional.
Old Apr 11, 2014 | 11:21 AM
  #25
Ferocity02's Avatar
If you want to get technical, you don't absolutely need any gauges. But if you are to get some, definitely wideband first and boost is a close second. If you get an electronic boost controller most should display boost so you don't need a separate boost gauge.
Fuel pressure is good as well, however a drop in FP will show as lean on the wideband. I have a pressure sensor on the rail so I can log it while tuning to ensure the pressure is staying up. Then when I'm not logging I just keep an eye on the wideband.
Oil temp is also good since the turbo is a nice oil heater.
Old Apr 11, 2014 | 12:27 PM
  #26
bud8fan's Avatar
PLX can monitor 4 different things on 1 gauge.
I do wide band , boost/vac , fuel psi and tranny temp
Old Apr 12, 2014 | 10:26 AM
  #27
GRRR65GTO's Avatar
Yeah in our trucks there arent a whole lot of places to put gauges besides the pillar....
You could make a custom new cluster and see how many gauges you can fit in it
Old Apr 12, 2014 | 09:10 PM
  #28
LPCWS6's Avatar
Does anyone have a Zeitronix ZT-2. Here's a link.
Zeitronix Zt-2 : SEMA Award Winning Wideband Engine Datalogging System
Also check out this Display for it. I think it does everything but scratch your *** for you.
Zeitronix DashDAQ XL : Touch Screen Display for the Zt-2 Wideband Engine Datalogging System and OBDII Compatible Vehicles
Old Apr 13, 2014 | 10:49 AM
  #29
TURBHOE's Avatar
The problem with using wideband to find a drop in fuel pressure is, how do you know if it's the tune or the fuel press. I kept adding fuel to mine cause it looked like it was getting lean do to rpm and boost pressure. When actually my pump wasn't keeping up. Once the guage went in I could see it was a pressure issue.
Old Apr 13, 2014 | 12:33 PM
  #30
BlackGMC's Avatar
Resident Retard
Personally i cant stand my 3 pillar pod but i like knowing what is going on with my truck. Since i drive my truck everyday having the laptop in it to monitor crap would annoy the crap out of me. Given my personality not having all those gauges would make me worry. So i deal with the stupid pillar pod for simple comfort knowing **** is working.
