Turbo blowing into supercharger-will it work?
Old Sep 7, 2005 | 09:19 PM
JRsilverado's Avatar
There was an episode of Trucks that mentioned this. A lot of the old big rigs used that setup. The supercharger was gear driven off the the crank and the turbo was mounted directly to the supercharger (if I remember correctly). It was an odd setup.
Old Sep 7, 2005 | 09:23 PM
Originally Posted by Naked AV
Something tells me that 427 is underpriced....I think you'd end up spending more than $8990.00 to do it right.
if you wanted to go pay something like 15000.00 for a engine that can be build exactly the same or even better you go rite ahead and try to keep you head from wondering if you really got what you paid for .. youre probally one of those guys that wastes $10 in gas to get a part thats a $1 cheaper
Old Sep 7, 2005 | 09:38 PM
TXsilverado's Avatar
dang, settle down scooter
Old Sep 7, 2005 | 09:52 PM
Mr. Sandog's Avatar
Yeah, you got me dead to rights.
Old Sep 7, 2005 | 11:00 PM
vanillagorilla's Avatar
Yup, this is true. It must have not of worked too well, because I don't see too many big rigs with this setup anymore.
If you've go the mula, the time and the know how, then I say do it. Be different, but you better IC the turbo air before it hits the Radix.
Old Sep 8, 2005 | 12:41 AM
02sierraz71_5.3's Avatar
Id do it the other way around use the supercharger to spool the turbo right off the line. The sc would have to be able to move alot of air though or it would be fighting against the turbo.
Old Sep 8, 2005 | 08:38 AM
the old detriot desiels use to have the superchager with a big ol' turbo feeding it. Not a bad idea however
Old Sep 8, 2005 | 09:56 AM
duwem's Avatar
what would happen, you would have one empty pocket book and probably no power, thats like apples and oranges your working with, just not any bit practical, the only thing i could see would be the low end from the blower and the high end from the turbo, but thats what twin turbos are for and why new cars have 2 diffrent sized turbos that can be switched on and off electronically at different rpms. Unless you have a lot of money, a lot of time, and want ot see yoru truck be down forever, find something more conventional, might make a nice "show" truck if you could even get the thing to run enough to back it off a trailer.
Old Sep 8, 2005 | 10:17 AM
Mr. Sandog's Avatar
That's right...two turbos (not 'twin' turbos, as that implies they are the same), with one smaller and one larger...that's how it's done.
Old Sep 8, 2005 | 06:06 PM
TheRealSS's Avatar
13 Second Truck Club
i've heard of this...it's called compound charging
low end of a SC while top end of a TC.
