Turbo 4L80 gearing. Need some input from the truck guys.
Old Aug 6, 2012 | 12:53 PM
INTMD8's Avatar
9 Second Club/ LS1TECH Sponsor
Default Turbo 4L80 gearing. Need some input from the truck guys.
I'm building a 57 Cadillac with a twin 3076r 390 and a 4l80e. Rear tires are 29.8in tall. It will weigh around 5000lbs.
Since those specs are pretty close to a full size truck I thought this would be a good place to ask.
I would like to run a 3.50 rear gear to keep cruise rpm down. Also plan on running a rather tight converter. Is it going to feel like a pig in 1st gear?
Other options are more rear gear (which screws up the cruise rpm) or lower 1st gear in trans.
Any opinions welcomed.
Old Aug 6, 2012 | 01:03 PM
nonnieselman's Avatar
If your Turbos spool and come on strong down low,, no its gonna be amazing..
Now they do make a lower first gear set for the 80E but its not that big of a difference in numbers..
Old Aug 6, 2012 | 01:12 PM
I think it takes 1st from a 2.48 to a 2.75 and 2nd from 1.48 to 1.57.
Old Aug 6, 2012 | 01:25 PM
The 3.50 gears should be just right
Old Aug 6, 2012 | 01:59 PM
Now that i look at the tire size,, thats gonna be some good gearing..
most guys run 3.42s and 3.73s with a 28 or 29" tire.. so your right there in with the pack
Old Aug 6, 2012 | 02:27 PM
ZO6Ted's Avatar
Hey Nonnie a tranny guy told me those gears were only avail for earlier model 4L80s? Is that true? To the OP I'm thinkin not a super tight converter and it looks good to me.
Old Aug 6, 2012 | 04:45 PM
brent1976's Avatar
11 Second Club
Mines 5200lb, 370ci, single 76mm, 80e, with 373 gears with a 31.5" tire, so yours should be similar to mine. You'll be fine.
Old Aug 6, 2012 | 11:34 PM
INTMD8's Avatar
Thanks for the input guys, it's going together with 3.50's.
Old Aug 6, 2012 | 11:40 PM
Man i have no clue. I just read that some of the old RVs woth the 454/4l80 come woth the diff gear sets. And i knew a company made them now or some jibberish.
Just thought id throw that out there for the OP to think bout.
But i read that they arent near as strong as the factory .48 gears.
What stall are you running in the car?
Old Aug 7, 2012 | 09:53 AM
ZO6Ted's Avatar
Thats pretty much what I heard too.
kyle's v
Oct 4, 2015 12:37 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
Cowboy17
Jul 9, 2015 08:22 PM
