Turbo 4.8 (LY2) ?
Old Jul 19, 2013 | 05:21 PM
mongooseboy000's Avatar
Default Turbo 4.8 (LY2) ?
At what point or psi are you guys gapping your rings? mods in sig
Old Jul 19, 2013 | 05:38 PM
slammedsilvy's Avatar
I've seen people running really high pressures, 22+ for example who gap them. I don't know that I've seen someone mention gapping rings for anything less than 20 psi. Many factors here though.
Old Jul 19, 2013 | 10:06 PM
**** that is allot. im at 8 now but no meth. kicking it up to 12 but nothing hihger after that without meth,
Old Jul 20, 2013 | 09:37 AM
Once I get my 80e refreshed and back in, I plan to run 15+ on e85 and have no intentions of opening up the lower end to gap the rings.
Old Jul 20, 2013 | 01:04 PM
MustangPunk's Avatar
ditto
Old Jul 20, 2013 | 01:32 PM
what are u running for fuel? is ur truck flex fuel? and are u on meth? i thought of that but everyone says fuel pump n injectors wont hold. 63# injectors on stock fuel pump. mine is not flex fuel nor do i have meth. i wouldnt mind running 14psi on my big as boat as the 80e 1st gear is slow. a 601st on an 80e would be dope though lol
Old Jul 21, 2013 | 11:45 AM
patofdzb's Avatar
Currently running 15psi, no gapped rings, stock engine, ls6 cam, prc dual springs, 57lb injectors, 10gph meth, 80e, etc..
Old Jul 21, 2013 | 03:45 PM
oakley6575's Avatar
I'm in the process of swapping in a 4.8L for boost and I'm not going to gap the rings at all. Everyone I've talked to have had great luck running 20+ psi with fairly stock bottom ends
Old Jul 21, 2013 | 04:13 PM
FIC 80# injectors
truck was non-flex, I swapped in a flex fuel pump from a junkyard 5.3 truck
e85 only
Old Jul 21, 2013 | 08:12 PM
FIC 80# injectors
e85 only
yikes curious to see numbers and track times. im not fully tuned for 12psi but at 7psi i ran a 9.1 @79mph on my crewcab on 22's no slicks. spinning out the hole.
