Tuning AFR & Spark Effects On Towing?
Old Jun 25, 2009 | 05:00 AM
therock's Avatar
Default Tuning AFR & Spark Effects On Towing?
When a truck is setup to 6.9 to 7.0 PSI @ 11.8 to 12.5 AFR and a WOT 18.3 or so spark, how is the trucks towing power effected. Say a 24' boat with a 200 HP Outboard.
When or how can a tune take away from towing.
Old Jun 25, 2009 | 07:18 AM
JoeyGC5's Avatar
Think of it this way, are you gonna be pulling the boat at 100% throttle alll the time?
As long as the midrange portion of the tune is good, there won't be any problems.
Old Jun 25, 2009 | 12:34 PM
therock's Avatar
Thanks, I'm tune dumb so I had to ask.
Old Jun 25, 2009 | 12:59 PM
Atomic's Avatar
I have a gauge for that
If you are pulling at WOT for extended periods I would set it a little bit richer just to be safe.
Old Jun 25, 2009 | 02:26 PM
KySilverado's Avatar
You are going to see some odd loads that probably would not be touched on a dyno tune, I know I did when I tuned my truck pulling an empty trailer, road tuning it. Keep an eye on the AFR and listen for any detonation. I'm assuming you are still using the MAF so it shouldn't be as much of a concern as with an SD tune.
Old Jun 25, 2009 | 02:33 PM
therock's Avatar
Thanks, The different type of load thing makes sence.
stock48's Avatar
9 Second Truck Club
I'de shoot for about 17* @WOT. They will also try to ping when full boost hits. With the load pk boost will also come in sooner. So you might need to start pulling timing earlier.
Old Jun 25, 2009 | 10:08 PM
MikeGyver's Avatar
Yeah, I'm SD, and pulling a trailer is when I first noticed knock at part throttle, going uphill, with the converter locked.
One cool thing about pulling a my boat, which has a combined weight of about 3500 lbs, is how people are impressed that I can smoke my tires pulling a boat. They don't stop to think that with almost no tongue weight (200 lbs), it has the same effect as a line lock on a dragster's front brakes, the ability to spin almost endlessly.
Old Jun 27, 2009 | 01:41 AM
zippy's Avatar
You should be fine as long as your IAT table is working well. Heat is the biggest issue when towing which will cause the KR*. A SD tune for what you're doing would only work if it were a 2 bar and tuned in with and without the trailer to cover all area's of the tune. Just make sure your IAT table is in full tune and you keep good fuel in it.
Old Jun 27, 2009 | 08:15 AM
therock's Avatar
Thanks Guys,
Heh! I'm sure there will be no WOT trailer pulling.
Oobray
Jun 13, 2022 03:38 AM
Dirtywhite
Aug 5, 2015 04:10 PM
Ls3silverado
Jul 31, 2015 04:22 PM
GMCtrk
Jul 17, 2015 06:39 PM
hackrst
Jul 11, 2015 11:17 AM
