trying to hit 11s with turbo kit
Old Jan 26, 2010 | 08:04 PM
tallChevy's Avatar
Default trying to hit 11s with turbo kit
I am kind of a newb when it comes to turbos. I came across a trade for a turbo kit with a s475 with a 1.32 ar. I know this turbo is not the greatest for my truck and I may try to trade it for a smaller turbo. My truck is a 08 gmc ecsb with a 5.3l non flex fuel. I have alot of questions that I could not answer by searching.
1) what fuel pump should I run(I was thinking a walbro 255 with a boost a pump)?
2)what size injectors do I need(maybe 60# or is that over kill)?
3)how much boost will I need(I have no idea)?
4)should I run meth?
5) what should I do with the dod (just turn it off)
6)what guages do you guys run besides boost and a wideband.
If any of my questions have already been answered in other threads please point me in the right direction. thanks
Old Jan 26, 2010 | 10:53 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
1) altleast 1 WALBRO 255
2) i have a set of 60's i will sell you for $275 and no they are not overkill
3) is your motor stock?
4) depends on the boost level.. but its only insurance
5) .....no clue i'm poor and have a 02
6) EGT...FUEL PRESSURE...TRANSMISSION TEMP
Old Jan 27, 2010 | 06:07 AM
tallChevy's Avatar
my motor is stock but I am gonna add arp rod bolts. are you the guy who sells the 60s that are a direct swap? I know what egt stands for but what does it tell you?
Old Jan 27, 2010 | 07:15 AM
stock48's Avatar
9 Second Truck Club
Your list sounds pretty good. What truck do you have rc, ex, cc? 2wd, 4wd?
-Yes on the meth
-I would get rid of the dod.
-That turbo might work but you will need a big converter, or N20 to get it out of the hole. A T, or Tc76 might be a better choice.
-What about transmission mods?
-Traction?
-Tune?
Old Jan 27, 2010 | 07:36 AM
Coban's Avatar
Is it a turbo kit built for your truck? It seems like Trick was building one of these and there was a bit more work to be done. Unless he just wanted it to be unique....
It might be easier if it is Air/Water.
Old Jan 27, 2010 | 08:02 AM
mgonzo82's Avatar
I got a kit done by trick for my 08 Gmc with a 5.3 I run 2 225 walbro pumps and 60lbs injectors.all that was done to the motor was a cam kit.I think you will need to turn the DOD off. for gauges I run Fuel press. Wband and boost gauge also have a lvl 7 trans from FLT. I am hopping to be in the 11 in a couple of months
Old Jan 27, 2010 | 10:00 AM
yes they came out of a NBS truck
Old Jan 27, 2010 | 10:27 PM
tallChevy's Avatar
well I guess I am gonna put the turbo up for trade. maybe someone wants to upgrade. I have a stock 4l60e but I want to get a 4l80e. for traction I am adding a trutrac, long bars and drag radials. I will either get a tune from vengeance racing, or a blackbear in person tune.
Choda
Jan 22, 2026 02:03 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
fastjweb
Aug 15, 2015 10:47 AM
71ls2
Jul 20, 2015 11:53 PM
Cowboy17
Jul 9, 2015 08:22 PM
