Trick turbo installation and review
Old Apr 18, 2016 | 09:27 PM
  #281
crashmymax's Avatar
Originally Posted by madmann26
I wish I had only spent $9500 on mine. I'm into mine for about $24k.
That is a ton of money. My truck only books for 24k
Old Apr 19, 2016 | 05:23 AM
  #282
madmann26's Avatar
It is,
It is not including the front end being completely rebuilt nor is it including the new rack/pinion I had to have put in (also replaced the power steering lines).
When I had the 4.10's put in, the rear end was rebuilt, not including that either. Or the longtubes,
It's probably closer to 30k realistically. When the wife is done with school, I'm going to turbo this one and get me a daily beater. Probably a quadcab.
Old Apr 19, 2016 | 11:08 AM
  #283
crashmymax's Avatar
was going to turn over the engine today to prime the oiling system but just get a loud click or pop sound. Sounds electrical. I have the drive belt off the injectors disconnected and the plugs out. Any ideas on what I may have missed? Double checked the harness and cant find anything left unplugged. Battery is charged and good.
Old Apr 19, 2016 | 11:10 AM
  #284
Atomic's Avatar
I have a gauge for that
Are you sure the battery is good? All the big grounds connected?
Old Apr 19, 2016 | 02:32 PM
  #285
crashmymax's Avatar
The battery is good I put a jumper on it any way and still not turning over. All lights work. Its on a charger now just to make sure.
The only large grounds I know of is from the pass front head to the batt. The other is driver rear head to the firewall next to hood ground. Is there another somewhere I'm missing?
Old Apr 19, 2016 | 02:45 PM
  #286
crashmymax's Avatar
with the battery charging the starter is now engaging or running but not turning the engine. Will have to google it and see what I did wrong.
Old Apr 19, 2016 | 03:13 PM
  #287
Atomic's Avatar
Theres not a factory one on the front of the passenger head. Big ones are at the back of the engine, next to the cam sensor, and at the driver side middle of the block behind the power steering pump.
Old Apr 19, 2016 | 04:32 PM
  #288
crashmymax's Avatar
I removed the starter and bench tested it. Checked out ok. Put starter back and tried again same thing. Luckily GM as the auto start when you turn the key (keeps cranking for a few seconds) so I turned the key ran out and looked at the crank pulley and sure enough its spinning. So I am just an idiot and this is how an engine without spark plugs, belt, and injectors hooked up sounds. What a waste of time that was.
How much cranking will it take to prime the system? will my oil pressure gauge show pressure just cranking or no?
Old Apr 19, 2016 | 07:12 PM
  #289
lxcoupe's Avatar
Man what an ordeal! Hope you have better luck with the new motor. I've had the typical hiccups with any turbocharged setup but all in all it's been a lot of fun. I overbuilt from the get-go and went with a trusted tuner, although certainly not cheap. Looking forward to hearing your impressions when you finally go boosted. What trans are you running btw? Any chance you can run better fuel like E85? I made the decision right from the get-go that I wasn't going to f*ck with pump gas, and I didn't want to bother with meth for a DD. I am running a fat/low timing tune with E85 to give myself a serious cushion since it's my daily.
Check your power steering pump brace where it bolts to the block, or your a/c compressor bracket behind the compressor itself.
My BBP autocal should be arriving this afternoon and still waiting on the injectors no word from Jon yet.
Everything is mostly back together just need to install injectors and fuel rail
The only leftovers I have not bad I guess for first time
Hopefully I will have the truck running this week. Extremely nervous about it!
Including the price of the kit and all my troubles I now have about $9500 invested in adding a turbo to my truck
Old Apr 20, 2016 | 09:00 AM
  #290
Atomic's Avatar
well thats pretty funny glad you got it working
