Trick turbo installation and review
Old Apr 20, 2016 | 09:44 AM
  #291
crashmymax's Avatar
Originally Posted by lxcoupe
Man what an ordeal! Hope you have better luck with the new motor. I've had the typical hiccups with any turbocharged setup but all in all it's been a lot of fun. I overbuilt from the get-go and went with a trusted tuner, although certainly not cheap. Looking forward to hearing your impressions when you finally go boosted. What trans are you running btw? Any chance you can run better fuel like E85? I made the decision right from the get-go that I wasn't going to f*ck with pump gas, and I didn't want to bother with meth for a DD. I am running a fat/low timing tune with E85 to give myself a serious cushion since it's my daily.
Check your power steering pump brace where it bolts to the block, or your a/c compressor bracket behind the compressor itself.
Power steering pump brace took care of the larger bolt. Thanks.
My transmission is the stock 6 speed. I do have E85 available but it is expensive here and limited. I would not be able to make a trip across the state I don't think and I cant trust my wife to put it in when she drives the truck but it is something to consider. I think meth would be easier for me.
Old Apr 20, 2016 | 09:47 AM
  #292
crashmymax's Avatar
Originally Posted by Atomic
well thats pretty funny glad you got it working
It was funny usually something like that would **** me off but it made me laugh, sounds absolutely nothing like turning over a engine normally does.
Old Apr 20, 2016 | 11:38 AM
  #293
crashmymax's Avatar
What do you think about starting the truck and letting it idle up to temp. So I can check fluids and so on. Still waiting on black bear for base tune before driving the truck but figure just idling cant do any damage. Want to check with you guys first to make sure.
Old Apr 20, 2016 | 11:43 AM
  #294
lxcoupe's Avatar
It will be fine unless you've changed injectors. Even driving it out of boost is fine.
Old Apr 20, 2016 | 11:54 AM
  #295
crashmymax's Avatar
I do have the 80# injectors in it. My big concern is it still has the tune from O2 dynamics that melted the piston. It did seem to idle ok when he gave it back to me the first time. So I figure it would be ok at idle but I wont risk driving it. Hopefully BBP turn around time is quick I never asked how long it would take to receive the base tune before I ordered.
Old Apr 20, 2016 | 11:57 AM
  #296
Atomic's Avatar
I have a gauge for that
Yea idle is fine. Pretty much the only way to hurt an engine at idle is if it doesnt have oil in it.
Old Apr 20, 2016 | 11:59 AM
  #297
crashmymax's Avatar
I guess its time to fire it up then and see what happens. Thanks
Old Apr 20, 2016 | 12:00 PM
  #298
lxcoupe's Avatar
Or wash the cylinders with too much fuel?
Old Apr 20, 2016 | 01:17 PM
  #299
Atomic's Avatar
If it was rich enough to do that, it most likely wouldnt even idle. Washed cylinders usually comes from multiple failed starts.
Old Apr 20, 2016 | 05:51 PM
  #300
A4edwin's Avatar
Anxious to see how that bb tune does.
