Trick Turbo Entry Level Kit
Old Jun 30, 2019 | 02:28 PM
'pacheMarshal's Avatar
Default Trick Turbo Entry Level Kit
I was looking at the entry level kit made by Trick Turbo and noticed it makes 400-500 hp. I wondered why there was a 100 hp range and what it took to make the 500ish hp. I have an aem water/methanol kit already and was planning on installing that after the turbo kit was done, it's just a single nozzle so nothing too crazy.
Old Jun 30, 2019 | 03:03 PM
03sierraslt's Avatar
The amount of boost you run determines the power level.
Old Jun 30, 2019 | 07:24 PM
FFDP's Avatar
Size of the engine will play a roll too. A 4.8 won't make what a stock 6.0 does with boost.
Old Jun 30, 2019 | 08:34 PM
Choda's Avatar
check my build threads. youll be fine with the stage 2 kit.
Old Jun 30, 2019 | 08:44 PM
i'm sure an entry level kit will be fine for me until I get the urge to turn up the boost. Truck is a 2002 with a cam and a 5.3 and flex fuel injectors.
Old Jul 2, 2019 | 07:55 AM
TrickTurbo's Avatar
Truck Sponsor
Like others have mentioned.
The engine size, boost level, cam shaft, tuning are just a few that effect final hp numbers.
Smitty's '04 GTO
May 22, 2009 01:14 PM
Billiumss
Aug 28, 2006 01:32 PM
1slow01Z71
Feb 6, 2006 10:20 PM
