Trick performance hardware sizes?
still looking for the exhaust leak in m system! Does anyone know what size the studs are in the turbo manifold that hold down the turbo and the bolts that bolt on the wastegate?
Gate is m8.
Is gate vented to down pipe?
Leaks can be found usually by the exhaust tracking. " black mark" at sealing areas.
I've tried tightening everything I can see but I'm going to pull the turbo and try to see if maybe a manifold bolt isn't on good. The bolt on the front right of the turbo is a pain to get a wrench won't fit on in between the compressor and the exhaust side. Has anyone tried a bead of the high heat red etc to help seal the turbo mounting surface?
You may be able to tack weld either the nut or the bolt to the flange in some cases if you can get on one side and not the other. I used copper silicone on my flanges. Don't have a ton of run time but seems to work well.
