Tired of STS
Old Aug 15, 2006 | 05:47 PM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
so if you flip the manifolds, do you have to move/lose any of the accessories, like ac or moving the alternator?
Old Aug 15, 2006 | 05:48 PM
Banned
Originally Posted by kbracing96
Problem with flipping the stock manifold is, it is pretty close to the coil packs and you would have to relocate them or build heat shields and run longer plug wires around one end of the manifold.
I going to be building a turbo manifold like the ones Parish built but for only a singe. Using the stock manifold on the DS and having a cross over come under the truck and into the back of the log with the turbo mounted on the other end of the log. This setup is going on a 5.3 I'm putting in my dads '72 4x4 long bed with air bags . Its being built out of schedule 10, 304 stainless pipe (about 1/8 wall). Should be pretty durable. If it works well, I may build a couple more .
Hey man... Where did you get that Alternator Relocation thing??
PM me!!
Thanks
Old Aug 15, 2006 | 05:57 PM
kbracing96's Avatar
PM me!!
Thanks
That's the stock location on a truck, at lease on mine and that's from a 04 Tahoe
Old Aug 15, 2006 | 06:52 PM
Banned
Maybe it is... It just looks wierd in that picture!?!?!?
Old Aug 15, 2006 | 06:55 PM
kbracing96's Avatar
That's cuz there's no intake on the motor Makes it look like it's higher then it is.
Old Aug 15, 2006 | 06:56 PM
TieRod's Avatar
GOGO-C you have a PM
Old Aug 15, 2006 | 07:21 PM
Stoichiometric's Avatar
With a livernois style manifold on the pass. side, does anything else need to move besides the a/c line and heater hoses? Any tips on how to move the a/c line?
Old Aug 15, 2006 | 07:50 PM
TurboGibbs's Avatar
Originally Posted by GOGO-C
M J . Do you have the turbo supported anyway besides just sitting on the flange. In 03' we built an Outlaw 10.5 Cobra Mustang with 100mm turbo . we used all kinds of braceing on that thing. Maybe thats why your manifold is cracking . If the log manifold is made of thin wall exaust tubing the viberation, heat, and the weight of turbo will desrroy the manifold . is your sutup Parishes Old? I will hit a little more on this tomorrow .I have to get ready for work now .
Yeah, it is Parish's old manifold and yes it is thin walled stainless. The weight of the turbo is part of the problem for sure but stainless is just wore out from too many heat cycles and especially high-heat cycles.
Old Aug 15, 2006 | 08:38 PM
just not satisfied with STS .My truck is an 04' Put on STS when the truck had 7000 mi. the truck now has 70k and just never been satisfied. Maybe the Tune not shure. I also dread the rain when i am traveling.
I would be curious as to some more details why you dont like it. We have been working to overcome some of the shortcomings of the system. There are some things that really make a difference on it.
Old Aug 16, 2006 | 09:11 AM
NXRICKY's Avatar
Former Vendor
I just grabbed ahold and pulled mine out of the way.. The long stem of aluminum off the compressor made that area pretty easy to move, then the other end of that line was a little tricky. But was not bad. Then wrap it up with thermo sheilding and call it a day.
If you pull to far or kink the line you have to get another one, or have one make. So care should be taken in doing this.
Ricky
