Thoughts about my BOV
Old Nov 10, 2008 | 11:02 PM
thunder550's Avatar
High on diesel fumes
Default Thoughts about my BOV
I have a Synapse BOV installed. This one acts differently than most....it is open until I hit a little bit of boost, then it closes and I can build more boost. The boost keeps it closed.
My question is regarding fuel efficiency. Since the BOV is open and venting air until I actually start building boost, it vents a lot of the air that the turbo generates, which gives the restriction of the turbo in the exhaust but without the benefit of the better airflow into the manifold.
Do you guys think that this would very negatively affect gas mileage? It makes sense to me but I wanted to get some other opinions.
Old Nov 10, 2008 | 11:09 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Since you are in vacuum does it make a difference? Turbo plumbing confuses my feeble old brain. What are you getting for mileage right now?
Old Nov 10, 2008 | 11:17 PM
kbracing96's Avatar
Your BOV should be fully shut buy the time you get to 0 vac...
Edit: it should just barely be closed when sitting idling
Old Nov 10, 2008 | 11:21 PM
thunder550's Avatar
I thought most (TiAL, etc) were closed all the time, except when purging excess pressure when the throttle blade shuts.
thunder550's Avatar
The actual charge pipes never see vacuum. Vacuum is only generated behind the throttle body.
Old Nov 10, 2008 | 11:22 PM
53RUSSELL's Avatar
Wow that new one to me.
Old Nov 10, 2008 | 11:26 PM
53RUSSELL's Avatar
Yes that how mine works
Old Nov 10, 2008 | 11:44 PM
kbracing96's Avatar
Ya, most of them are, it depends on how stiff the spring is. If properly setup, the spring should just be set tight enough to hold it shut at idle, but then when you let off the throttle while boosting, the boost pressure and higher vac you pull when in decel should fully open the valve until the pressure is fully release.
Old Nov 10, 2008 | 11:49 PM
charcold-bowtie's Avatar
Just a thought, I swear mine makes a chatter noise when you let off the throttle in vacuum.
I dont think it would have a huge effect, do u get into boost that much, maybe try to keep the tc unlocked a bit more. That itself helps me stay outta boost quite a bit.
Old Nov 10, 2008 | 11:51 PM
08DenaliT's Avatar
yea but the synapse bovs are very wierd they dont have diaphrams. we put one on a procharger murauder at my shop im kind of up in the air about them.
